Samsung ATIV Smart PC 500T factory reset
Discussion in 'Samsung' started by wyzard, Jan 18, 2013.
  1. wyzard
    wyzard Pen Pal - Newbie
    I am trying to do a factory reset on my ATIV 500T but it is asking me to insert media. This is tablet and obviously doesn't have a cd drive. I don't have anything to install. Anyone have any suggestions on how to factory reset this without media or to bypass that request.
    Thanks.
  2. DanaC
    DanaC Pen Pal - Newbie
    I had the same problem but it ended up I had to send it for service. First they say it needs re-image, it's a software problem and it's not under warranty then it turns out for me that it's a hardware problem and that is under warranty.
  3. amdhunter
    amdhunter Pen Pal - Newbie
    That is unacceptable. Extremely unacceptable.
    As someone who is very capable of installing Windows, I'd be really mad if Samsung told me that I had to send it to them, and on top of that, pay them to do it for me.
    This pisses me off to no end. Although there are ways to clean install Windows, Samsung should NOT be telling people it will cost money to re-image a device.
  4. DanaC
    Tell me about it! I was so pissed but I had to send it in anyways because it would not boot up. I told them that I didn't put in the windows 8 software they did, they didn't care! Samsung's customer service is not very good.
    I finally got my tablet back from repair, the repair center lost my S-Pen!!! I had to call the customer service and wait another hour for someone to deal with my "problem" and that's another 3-5 days for them to send it to me!!! I just want to SCREAM!!! I will NEVER buy from Samsung AGAIN!!!
  5. bigliljoe
    bigliljoe Pen Pal - Newbie
    I hope this answers all of your questions. It is a lot easier than you might think to reset to factory settings. First bring ip the onscreen keyboard. Once it is up, press the shift key. The shift key should be highlighted. Now press the power button that should be located in the bottom left hand corner. You now have a few options. Select reset, it will ask you if you would like to simply reset your computer or to erase all files. Select the option to erase all files, the reboot should take about 30 minutes but your samsung is now reset to factory settings.
  6. Atcold
    Atcold Pen Pal - Newbie
    The procedure, under Windows 8 is:
    1. Click on Settings (on the right Win8 tool bar)
    2. More PC settings
    3. General
    4. Reset your PC and start over
  7. arcinla
    arcinla Pen Pal - Newbie
    This did not work. Is there a way to reset the device from the initial login screen? I haven't used my device in a few months and don't remember the password. I'm trying to give it to a friend, but it's making it difficult.
  8. MSGaldenzi
    MSGaldenzi Scribbler - Standard Member
    372
    63
    In no way do I mean to call you out, but samsung did say when I sent mine in to "NOT INCLUDE ANYTHING OTHER THAN THE TABLET"... I didn't give them my spen because I figured they would snatch it. Still, sucks you got the shaft from them.
  9. restodo
    restodo Pen Pal - Newbie
    I had the same problem and the solution was made doing this.
    Refresh or Reset Windows 8 without Installation Disk
    Previously I had to go to CMD and using DISKPART command, assing a letter to RecoveryImage partition.
    After doing this, I select again Reset and everything goes good!
    Hope it helps!
  10. restodo
    Try this link:
    Before doing this steps, I have to use DISKPART command to assign a letter to RecoveryPartition to point the command line of this website to D:\RecoverImage for example.
    After doing all the steps, I try Reset again and it works!
