RESOLVED: Vivotab Note 8 M80TA - Inaccessible Boot Device - After Win10 Reset
Discussion in 'Asus' started by dgosho, Dec 27, 2017.
  1. dgosho
    dgosho Pen Pal - Newbie
    Hi. My Asus Vivotab Note 8 M80TA was acting buggy, so I did a Windows 10 reset.
    After a couple restarts I now get the blue screen with a sad face that says
    Your PC ran into a problem and needs to restart. We'll restart for you.
    If you'd like to know more, you can search online later for this error: INACCESSIBLE BOOT DEVICE.
    Then it just keeps rebooting and showing this message.
    Any thoughts for what I can do now?
    Thank you,
    -David
  2. Kumabjorn
    4,312
    2,382
    Have you removed the Recovery section?
  3. jjsa1985
    jjsa1985 Scribbler - Standard Member
    191
    117
    This probably does not apply to you but just in case, do you by any chance still have the micro SD recovery card in the tablet? If so, I would take it out and try the windows reset again. Thats the only thing I can think of.
  4. dgosho
    No.
    On this device, I did an upgrade to Windows 10 about 2 years ago. It's been running fine until recently.
    All that I did was run Reset this PC and selected Get Rid of Everything.
  5. dgosho
    This tablet didn't come with a recovery SD card.
  6. dgosho
    RESOLVED:
    I was able to do a clean install of Windows 10.
    Here are the steps I took.
    On a different PC
    Download Windows 10 Media Creation Tool from here:https://www.microsoft.com/en-us/software-download/windows10
    Launched the tool and, using a USB drive, created a Windows 10 installation
    On the tablet
    Used a USB OTG cable, and an unpowered USB hub to connect the Windows 10 Installation USB drive, a mouse, and a keyboard to the tablet.
    Entered the tablet bios by first powering up (hold the power button for a couple seconds until the LED near the camera lights up) and then immediately holding down the power and volume down buttons.
    In the bios (you can navigate the bios through touch, the buttons on the tablet, or the keyboard), I selected boot and for the first boot option i selected the usb drive then saved and exited.
    On reboot, I selected a clean install of Windows 10.
    I chose the larger of the two hard drive partitions (in my case that was about 45GB).
    Go through the steps of Windows 10 install.
    Once installed it is missing a number of drivers.
    Go to the ASUS driver page, here: https://www.asus.com/us/Tablets/ASUS_VivoTab_Note_8_M80TA/HelpDesk_Download/
    There are only a couple drivers available under windows 10, but the Windows 8 drivers work for audio and pen, so go through the list of drivers and install them.
    Finally, I went into device manager and found a number of "unknown device"s. I right-clicked and selected "update driver" on each of them. That worked for all but one of them.
    Now the tablet is back to normal with a clean install of Windows 10. Both touch and pen input are working fine.
    Shiratori, Dede, hiramkey and 2 others like this.
  7. Cool_Breeze
    Cool_Breeze Pen Pal - Newbie
    I'd like to find a similar way to reset my bios. It currently boots to a blank screen. It is not a Windows problem.
  8. Kumabjorn
    4,312
    2,382
    On my USB hub the mouse isn't recognized. Any ideas?
  9. Kumabjorn
    4,312
    2,382
    I've done the same thing. Except I don't have the pen working.
    Do you remember what you did to get the pen working?
  10. Kumabjorn
    4,312
    2,382
    Perhaps I should clarify a bit.
    When I approach the screen with the Asus stick pen I get a hover cursor, but as soon as I touch the screen with it, the digitizer (for pen) dies. But with a S-Pen (original Note) and Bamboo stylus I get pen recognition for something like 30 seconds and then that also goes poof.
    I've actually had this before, but I can't remember how it as solved. I have installed both the Asus Dual Touch driver and the Wintab 32-bit driver. But I'm missing something.
