Replacing Venue 8 Pro USB port... Messy
Discussion in 'Dell' started by pr3s, Jul 30, 2017.
  1. pr3s
    pr3s Pen Pal - Newbie
    My Venue 8 Pro's USB port died like many others. I tried replacing it at the time (a couple or more years ago) using hot air method but could never get the new port seated correctly (I now think a tab might have broke off in one of the through holes).
    I was cleaning up and came across it again and decided to try again. Under magnification I discovered I shmushed a couple of SMD off their tabs the last time round. They are two tiny SMDs down and to the left of the of the connector on the connector/back side of the board. In trying to replace them I lost one. Are these capacitors? If so is there a way anyone can find out what capacitance they are? I'm also wondering if I can salvage one from the unused USB ports on the board.
    Any idea how much a cell repair shop would charge to replace it if I just brought the bare board in? I'm terrible at this.
  2. chevypad
    chevypad Pen Pal - Newbie
    54
