Replacing my ativ 500t and galaxy note 8
Discussion in 'What Tablet PC Should I Buy?' started by drvenom, Apr 25, 2016.
  1. drvenom
    drvenom Scribbler - Standard Member
    151
    General Questions.
    1. What is your budget?
    $400 USD but I can probably stretch that to $550
    Yes
    I prefer a slate. I'm looking to replace my Ativ 500t and galaxy note 8. I prefer the OS to be windows or android.
    7.1 to 10-inches; It can be an 8 or 10 inch. If the tablet is light enough and has good battery I'll even consider a 12 inch.
    USA
    No preferences. Well, I don't think I can buy an apple device because of IOS.
    At least 7 hours. I get about 10 hours and days of standby on my Ativ 500t.
    I will mainly use the tablet for office work: Email, Web Surfing, PDF annotating, Note taking, and some light entertainment. Having said that, the most important thing is note taking. I can't stress enough how great the palm rejection has to be. I write notes fast and I need the tablet to keep up with me. I've had to resort to turning off touch on most of my tablets so that I can ink without having my palm accidentally zoom in or scroll across the page that I'm inking on.
    No IOS for me
    Mainly microsoft office and pdf softwares like adobe and the like.
    No
    It would be nice, but that would not be the primary function of the device.
    1080p is the minimum. I know people think that high resolution is not necessary on smaller screens, but I think it is. Text looks awhole lot better on high resolution devices. The text on my note 5 is so much crisp compared to my 1080p screens.
    I will be using the tablet primarily indoors, but yes I would like to use it out door on certain occasions. However, I can do without the future if having it will break the bank.
    I've always used wacom devices, but I could care less as long as the device is accurate when it comes to taking fast notes and has great palm rejection.
    Component Specifics
    I would like to have a minimum of 64GB of hard drive and 4GB of ram.
    Micro SD would be great.
    Misc:
    I'm going to repeat my self a little bit here. I'm looking to replace my ativ 500t and galaxy note 8. I'm looking for something fanless and that has a long battery life, at least 7 hours. But the most important thing is that the device does great at note taking. One of my pet peeves is that I currently have to turn off the touch feature on my ativ 500t so that my palm doesn't accidentally zoom into the page that I'm inking on or scroll across the page. As you can imagine, that gets pretty annoying. My galaxy note 8 does pretty well with palm rejection, but the calibration is completely off and the inking precission isn't all that great. I sometimes miss how wonderful inking was on the HP 2710p and Gateway M290. Anyways, thank you all for taking the time to read my post and for your recommendations.
  2. drvenom
    151
    I ended up pulling the trigger on a Galaxy Tab 10.1 2014 edition. I did a hard reset on my galaxy note 8 and the calibration adjusted and the inking is working a lot better, which made me reconsider the galaxy note line. I also found a manufacturer refurbished Note 10.1 for $279 which is a fantastic price given that it has a high resolution, wacom digitizer, ect. Let's see how it turns out. :)
