Replacement power cable for Vivotab 810
Discussion in 'Asus' started by mm289, Feb 18, 2014.
  1. mm289
    mm289 Tablet Business User
    35
    Hiya,
    anyone know if the power cables from other Asus products eg transformer prime are compatible with our 810's?
    Mine has stopped working but over here in the UK I can't find a replacement cable listed anywhere for the 810. Lots for the Prime and EEpad which look similar but want to check before purchase.
    Cheers :thumbsup:
    MM
  2. Conrad Hart
    Conrad Hart Pen Pal - Newbie
    The USB charging capable for the TF701T is the only other Transformer cable that will work.
    The connector for the TF101, SL101. TF201, TF300, and TF700T are all the same. But they WILL NOT work with our TF810C. The TF810C/TF701T uses a slightly smaller proprietary cable.
  3. schwarz86
    schwarz86 Pen Pal - Newbie
    90
Similar Threads - Replacement power cable
  1. ElBiggus
    771
