Replacement battery on HP site
Discussion in 'HP Slate' started by johnmcd, Dec 7, 2010.
  1. johnmcd
    johnmcd Scribbler - Standard Member
    183
  2. latinvixen
    latinvixen Artist
    262
    Oh I do hope that is the case, would not mind having and extra battery :)
  3. darkmagistric
    1,999
    1,060
    How?...the back is a single textured surface....any attempt to replace the battery looks more like a voided warenty nightmare in the making.
  4. wubbzy
    wubbzy Pen Pal - Newbie
    73
    Something's not right. Based on the dimensions listed on the web site, the battery is larger than the Slate itself. With this and the incompatible power adapter still listed on the web site, it seems that HP's left hand doesn't know what its right hand is doing.
  5. jgjackson
    jgjackson Scribbler - Standard Member
    485
    That's the battery for the mini100e.
  6. DaveP
    377
    I suspect that the HP database is fouled up. The power supply they were showing was also incorrect. If I had to guess, it thinks the HP Slate is just another version of the HP Mini (which is also why the Slate shows up in the Mini category).
  7. johnmcd
    183
    Something's not working correctly at HP? I'm shocked, I tell you - shocked! :eek:
