[Release] RadialMenu
Discussion in 'Software' started by incrediclint, Oct 1, 2014.
  1. incrediclint
    219
    50
    But are profiles working for other applications for you?
  2. loumizhu
    loumizhu Pen Pal - Newbie
    Yes
    I tried Notepad++ it worked
    Tried Krita 64, it didn't work
    Tried Photoshop 32 , it worked
    it seems 64 applications don't work
  3. Gleurk
    Gleurk Pen Pal - Newbie
    I've got same issues here. Just Discovered your Tool that seems to be amazing. Creating Profile is working , but when i'm switching from an application to the other , the profile didn't seem to switch, even if i freshly start an application with a applied profile.
    Also i was wondering how hard it would be to make the radial Menu appear center on the mouse cursor instead as the middle of the screen.
    Just my one penny suggestion.
    I hope that i don't sounds like a spoil brat. I would like to thank you for your hard work, what you've accomplish is really impressive, but also really useful. Is there a way to help you by donating somewhere?
    Thank you again
  4. incrediclint
    219
    50
    Hmm, good to know. I'll see what I can do.
    It should appear centered on the mouse when activated with a hotkey.
    If activated using the button on the toolbar it should appear in the center of the screen. If this is what your talking about, I can add an option for this so it appears at the mouse location.
    loumizhu likes this.
  5. incrediclint
    219
    50
    I'm having a problem on my TabletPC when using the rollup button. Turning off the "UI buttons on top" setting then clicking the rollup button the toolbar moves down a little bit when it hides the buttons. This doesn't happen on my desktop, is anyone else having this problem?
  6. incrediclint
    219
    50
  7. incrediclint
    219
    50
    Here's the projects donate page: http://radialmenu.weebly.com/donate.html
    Your requests aren't a problem :) Easy fix.
