[Release] RadialMenu
Discussion in 'Software' started by incrediclint, Oct 1, 2014.
  1. surfaceproartist
    2,930
    1,893
    Guys, between the two of you, we have an embarrassment of riches!
    Clint, how do you close the toolbar once you've opened it?
  2. Kumabjorn
    4,308
    2,425
    Do you need to delete the old one, or do you just install on top of it?
  3. incrediclint
    219
    50
    The toolbar is always visible but can be made smaller with the rollup button (the up arrow icon). I'm going to add an option to disable the toolbar for those that don't wait to use it as well as docking/autohide options and the ability to collapse it to an even smaller size.
    Wife was getting a bit upset at all the time I been working on it the past couple days so I had to put it away for the day:)
    Install on top. If you want to start fresh and/or backup your settings navigate to c:\users\USERNAME\local\RadialMenu\RadialMenu.exe_Url_1t2jsfhaqup4qihqkwkkkronizlidbb2\0.1.84.XX
    Your path will be slightly different but in that folder is a file "user.config" where all settings are stored. Move or delete that file and when you run radialmenu it'll create a new one as if it's a fresh install.
    Kumabjorn likes this.
  4. loumizhu
    loumizhu Pen Pal - Newbie
    Wow, Great job with this update :)
    You even added a toolbar. This is awesome software you have. Huion and other cintiq alternative should pays you.
  5. incrediclint
    219
    50
    RadialMenu 0.1.84.47 - released on October 11, 2014
    - Removed commands: AltToggleCommand, CtrlToggleCommand, and ShiftToggleCommand
    - Added KeyToggle command that allows any key to be toggled.
    - Added indicator for buttons that are toggles.
    - Modified settings display for the toolbar and cleaned it up.
    - Added profile settings for the toolbar.
    - Added option to disable the toolbar.
    - Added: button size options to toolbar designer
    - Changed: toolbar row/column editor to spin buttons
    - Fixed: Save toolbar row/column and button size settings.
  6. loumizhu
    I wanted to try last version , the download buttons of 0.1.84.45 and 0.1.84.47 seems dead.
    for a stange reason, the radial menu for a specific exe file show me the standard one.
  7. incrediclint
    219
    50
    There was a problem with the toolbars editor that could wreak havoc on settings files as well as some behind the scenes stuff so I disabled the download. A fixed version will be released shortly.
  8. incrediclint
    219
    50
    New version of RadialMenu, the toolbar is now able to be collapsed down to a single icon for use solely as a radialmenu activator. This version feels pretty stable to me and the toolbar addition is at a very usable state, so other then bug fixes, development on that portion of RadialMenu is going to slow down some :)
    A user guide has been added that's installed alongside radial menu.
    RadialMenu 0.1.84.49 - released on October 13, 2014
    - Added: Option to hide the rollup button.
    - Added: Option to hide the drag handle.
    - Added: Option to hide the icon.
    - Added: Auto collapse option.
    - Added: Option to put UI buttons on the bottom of the toolbar buttons.
    - Fixed: Toolbar scaling.
    - Fixed: Toggle key action selection was breaking buttons.
    - Changed: Max toolbar size is now 5x10
    loumizhu likes this.
  9. incrediclint
    219
    50
    I'll be looking into these issues over the next few days now that I got the toolbar to a usable state.
    "-Release hot key to select (less clicking): Hotkey down = the menu appear, user hover the desired item, hotkey up = item launched"
    This should be pretty easy to do.
    "-Possibility to choose background color and maybe transparnecy for each item for more visibility"
    This used to be an option about a year ago, along with font size, background color, border color, button shape/menu shape. I could put it back in if I find the time. I gutted most of that code because it was tied in with my old licensing system back when I was going to release a free version and an upgraded more customizable version for a few bucks.
    "-possiblity to choose bigger images and implement pngs (with transparency)"
    .pngs should work fine, but I haven't tried it a while, i'll see what's going on.
    "-possiblity too chose as hotkey : one finger touch, two/three/four finger touch (touch only). In the same Idea, doing a touch drag in a given direction (like 90°) would quickly fire the top item 45°=fire the right/top item"
    Touch input is a snap to handle in windows 8+, but not so much in earlier versions. I'll see what I can do, though I have no touch enable windows machine to test it with.
  10. loumizhu
    Hi Clint
    thanks for this update. Toolbar is great addition !
    I'll just report that the profile (or context sensitive) is not working for me:
    Tested on:
    Windows 7 - 64 (normal laptop)
    Windows 8 ( Surface pro )
    When I choose Photoshop.exe , make a menu for it. The standard menu appears when I'm in photoshop.
    Pngs transparency is working fine :)
    Also, if you want me to test something on surface pro.
