Really bad build quality! What do you think?
Discussion in 'HP TouchSmart TM2 (Wacom)' started by s3k7m5, Feb 26, 2010.
  1. s3k7m5
    s3k7m5 Pen Pal - Newbie
    23
    Well, i think i will send my second unit back too. Basically because of the crack. I can live with the bad clearance. But only in case that something happens in future, it will be better to have one without a crack. I'm afraid they could tell me that i broke it.
    And to get rid of the noise, i have to get a new HDD or SSD. Does someone know a good HDD that is less noisy and doesn't has so much vibration?
  2. Oliver Beyer
    Oliver Beyer Scribbler - Standard Member
    126
    That's a good idea anyway. I swapped the hdd for the Intel Postville G2 80GB and boy, does that make a difference. The speed increase in daily use workload is incredible. And as a bonus, my TM2 is dead silent now.
    When booted into W7 the fan stops completely. And since there is no hdd noise anymore, it's totally awesome.
    If you don't need a huge amount of space I'd go with a 80GB Postville SSD. They are pretty affordable these days. I pays ~190 Euros for mine from Amazon. You only need the bulk version since extra screws and a 3.5inch frame are hardly useful for a laptop. The change is exeptionally easy too and HP deserves some credit for that!!!
    I wanted to swap to SSD on my old LG laptop but I would have to take the entire thing apart to reach the hdd so I posponed the idea.
    The thing with the vibration and noise is, that the hdd in the TM2 is 7200rpm one. It's quite fast - for a hdd - but those high rpm generate noise and vibration. If you want space, I'd look for a fast 5400rpm drive. They are nearly as fast as the 7200rpm ones but much better in respect to noise and vibration. If you don't need the space internally, get a Postville SSD and some nice external HDD if you need some storage. The TM2 with SSD is pure awesomeness.
  3. black88mx6
    black88mx6 Pen Pal - Newbie
    61
    My first tm2 had a bad clickpad. My 2nd unit is good, but the battery moved around slightly. I even switched in the original units battery before I sent it back and it was loose also. Both batteries in my original unit were solid with no movement.
  4. corecomps
    corecomps OSX86 User
    33
    Seems like there are a number of quality issues on these machines. Perhaps expected for a brand new model but I hope they tighten things up quickly. They are the first to this market but certainly not the last. You have non pen input PC's with similar specs in the $500 range. The recent coupon to bring the price down to $650 is a bit help in getting it a solid foothold. I'm sure there will be many hitting this market shortly as touch input is the next big thing.
  5. heatlesssun
    2,320
    I think its a consistency issue primarily. I'm sure there are some kincks that they need to work out and I'm sure it will get better.
    But my machine came together pretty solid I think. It's not perfect but this is a well built consumer tablet overall. I've seen MUCH worse over the years.
  6. Malangyar
    Malangyar Pen Pal - Newbie
    95
    What is done with all the returned units? They must be piling up somewhere.
  7. Oliver Beyer
    126
    Usually they can be sold as refurbished ones when they are fixed. I know if they are sold in the open markets but we (in the old company I worked) could get entire refurbished batches at a much cheaper price. That wasn't the TM2 though.
  8. Meatlocker
    Meatlocker Software Development Pro
    208
    My last TM2 had a bulge on the left side of the screen bezel, where either something underneath was not seated correctly or it was warped - either way, it couldn't be pushed back in. I could have lived with that, but what I couldn't live with was a tilt in the screen hinge that made the left side of the screen lower than the right by a couple of centimeters. When I closed the lid and looked at the hinge, I could clearly see a gap in the hinge on the right side that was causing this. Too much money not to get a unit that is built correctly.
  9. corecomps
    33
    I will say that HP's 21 day return policy is great! 2 minutes on the phone, an instant e-mail with a prepaid label and no cost to me.
