Random Lockups when on battery
Discussion in 'Lenovo (IBM)' started by Dolvich, Jul 3, 2007.
  1. maverick46
    maverick46 Scribbler - Standard Member
    104
    I've been running two days with TM enabled and the crashing has stopped. Seems that the matrix storage driver has fixed the issue.
  2. jywang
    jywang Scribbler - Standard Member
    233
    I wanted to give a quick update on my experience with the new TM drivers. At first, the new drivers seemed to work for me. I had installed them using the instructions I gave in this thread. However, after a few lockups and forced reboots that caused startup errors, I gave up and did a fresh clean Vista install with the new drivers instead of upgrading from the old drivers. This method seems to have worked for me.
    There were a few pieces of software I did not reinstall the second time around so there is a small chance that one of the them might have been causing my problem. Regardless, I have finally been able to sleep and hibernate and use my X61t without any lockups and forced reboots.
    I will make a posting soon on my clean install steps.
  3. curarine
    curarine Pen Pal - Newbie
    I'm guessing a lot of people (myself included) developed enough data corruption before installing the 7.6 drivers to cause continued occasional lockups and application errors. Therefore, I think the clean install's a good idea, and will likely follow suit soon just to make sure i'm starting on solid ground.
  4. tngreene
    tngreene Pen Pal - Newbie
    After 3 weeks of frustrating lock-ups, I tried the new Intel Matrix Drivers, and was able for the first time ever to use the laptop in tablet mode with no crashes. It's only been 1 day, but this is the best sign yet.
    Another question (perhaps related, perhaps I should make it another thread): After I boot into Vista, the hard drive light flickers (i.e. the HD is being accessed) consistently. In XP, after a few minutes of boot up time, the HD would go dormant, but now, its constantly being accessed, even if I don't touch it for 20 minutes, with no programs running.
    Is this normal for Vista? Related to lock-ups we're experiencing? Or something altogether different?
    Thanks....
  5. g2tl
    g2tl Scribbler - Standard Member
    567
    It's superfetch.
    I tried disabling it, which did stop the crazy hdd party after booting up.
    I turned it back on as I actually saw a noticeable difference in performance.
    Besides, if you check using the performance and reliability monitor, the transfer rate of what superfetch does is small enough to ignore and do whatever I need to do.
    My only complaint is that I wish I could stop it when I'm on the battery.
  6. tngreene
    Thanks..that explains it. Guess it;s not related to the lock-ups, which is good news. And, another 8 hours later, still no more lock-ups. I'm about done holding my breath.
    Re: the superfetch, I wonder how much extra strain, if any, its puts on the HD...think the numbers of HD failures will start rising as more people have Vista/Superfetch?
  7. krypticide
    krypticide Scribbler - Standard Member
    218
    I get very infrequent lockups, maybe 3 times now since July 6, even with the new matrix drivers installed.
  8. krypticide
    218
    Argh, lockups happening more often now... seems to kick in when Active Protection does.
  9. doctorcilantro
    doctorcilantro Scribbler - Standard Member
    JYWANG - Did you do a clean install with F6 option to install via floppy utility?
    I'm unclear on whether or not this is akin to a specialized SATA/RAID driver that must loaded upon install in the aformentioned manner.
    EDIT - I see that the 64bit floppy is an old version - I'll jut stick to the new one.
    thanks
    DC
  10. xtg05
    xtg05 Pen Pal - Newbie
    Have you tried to DISABLE the Windows Hybrid Hard Disk Power Saving option?
    You can find the option from [Control Panel]-[Power Options]-[Change plan settings]-[Change advanced power settings]-[Hard disk]-[Windows Hybrid Hard Disk Power Savings Mode].
    I recently disabled the option, and now I have been without any kind of lockups for 6 days with my ReadyDrive-enabled X61T.
    Try it, and give me some feedback.:)
