RadialMenu/Toolbar 0.4.6.326
Discussion in 'Software' started by incrediclint, Oct 15, 2014.
  1. incrediclint
    219
    50
    Yea, it should. Try the ones with a UsagePage of 13 and Usage of 4 or 2. Although, I just ran across some AHK scripts that have some data I can use as well.
  2. ron2k_1
    992
    171
    Surface Pro 3 N-Trig
    Usage 13 Page 2
    Index [9] = 0 Pen is not in range
    Index [9] = 1 Pen cursor is in range
    Index [9] = 3 Pen is touching screen
    Index [9] = 9 Pen in range (hovering) with 1st button pressed
    Index [9] = 5 Pen in range (hovering) with 2nd button pressed
    Index [9] = 17 Pen touching screen with 1st button pressed
    Index [9] = 7 Pen touching screen with 2nd button pressed
    1st button = Button closer to pen tip
    2nd button = Button closer to pen top
    I'll follow with the Lenovo X230t numbers later
    Sent from my Surface Pro 3 using Tapatalk
  3. Kumabjorn
    4,394
    2,551
    I'll try and verify that later.
  4. incrediclint
    219
    50
    Exactly what I needed! I'll squeeze in an option to test the buttons with todays release.
  5. incrediclint
    219
    50
    RadialMenu 0.2.7.124 - released October 31, 2014
    This release includes some pen testing features for RadialMenu, it can be toggled on and off in the settings window. Only supports Surface Pro 3 and Wacom Bamboo compatible tablets.
    The toolbar has basic touch specific code now, just for testing. I need to know if using touch on the toolbar steals focus or moves the mouse to that location, or if it has no effect on using both touch and pen at the same time.
    - Fixed: In 'Gesture' activation mode, when using 'Use Center Button as Right Click' and RightMouse as the trigger, letting go of the button over the center icon will perform the appropriate action (right click if mouse icon visible, hide radial menu if close button visible). Left clicking while while holding down the trigger button will do the same thing.
    - Added: Test settings for Wacom Bamboo tablet and Surface Pro 3 pen.
    - Fixed: 'Use Center Button As Right Click' problems in normal mouse activation mode.
    - Fixed: RadialMenu: Right click menu showing up when it shouldn't.
    - Changed: Changing applications while RadialMenu is visible will hide RadialMenu.
    - Added: Option to show submenus at mouse location.
    - Fixed: RadialMenu hiding itself in response to button clicks from the toolbar.
    - Fixed: Removed 'KeyHold' from command list since it doesn't actually exist.
    - Added: Toolbar: Show grid option when in designer mode.
    - Added: More tooltips. Popup dialog on first entering design mode.
    - Fixed: Toolbar: Buttons couldn't be removed in certain situations.
    - Fixed: Toolbar: Button resizing after drop when dragging them to a new location.
    - Refactored: Toolbar: Adding/Removing rows and columns is now much faster.
    - Changed: ToolBar: Buttons are no longer automatically added when increasing column/row count.
    - Changed: Toolbar: Can only reduce the column/row count if those columns / rows are empty.
    - Fixed: Toolbar: Error when reducing column/row size and a button that's been expanded would be removed by the change in columns/rows.
    - Changed: When using 'Gesture' mode and choosing a submenu RadialMenu will stay on screen.
    - Fixed: Bug that allowed RadialMenu to get stuck in a submenu until application switch was detected.
    - Fixed: RadialMenu not hiding after actions/buttons selected.
    - Fixed: Toolbar: Using 'AutoCollapse' didn't work correctly with transparent background.
    - Added: Option to keep RadialMenu on screen even after clicking/selecting an action or button.
    - Added: Some tooltips added to some controls.
    - Changed: Cleaned up the Toolbar settings UI.
    - Fixed: RadialMenu will ignore modifier keys for mouse activation if they are not being used for mouse activation, meaning that it will toggle itself when the mouse trigger button is pressed regardless if control/shift/alt/windows keys are.
  6. incrediclint
    219
    50
    BTW, for me anyway, radialmenu doesn't appear in the right position using my Wacom Bamboo pen to activate when using Internet Explorer... Didn't have that problem in testing though. If anyone else has that issue, let me know.
  7. ron2k_1
    992
    171
    That'll be great as the the amount of data spitting out of that Usage gets overwhelming and although I double checked each value, the opportunity for mistake is always there
    Swiped from my Galaxy Note 8 using Tapatalk
  8. ron2k_1
    992
    171
    And in the event you'd like to support the x230t, here are the numbers I got this afternoon:
    UsagePage 13 Usage 2:
    Index [9] = 32 Pen cursor is in range
    Index [9] = 36 Eraser end is in range
    Index [9] = 33 Pen is touching screen
    Index [9] = 44 Eraser end touching screen *
    Index [9] = 34 Pen in range (hovering) with 1st button pressed
    Index [9] = N/A Pen in range (hovering) with 2nd button pressed
    Index [9] = 35 Pen touching screen with 1st button pressed
    Index [9] = 44 Pen touching screen with 2nd button pressed *
    * Same Index value as probably my second button is being registered as an eraser in HidCapture.
    Note:
    2nd button = Button closer to eraser
    I used a UP-911E 2-button+Eraser Pen on Lenovo X230t Wacom Win 7 Pro
  9. incrediclint
    219
    50
    Same as my Wacom Bamboo, and the same as my Motion Computing LE1700/1600. So any of those profiles should work.
  10. incrediclint
    219
    50
    Modified version of HidCapture. This one lists some more info such as VendorID/ProductID and Revision number data about the devices on your system.
    If you guys could post the vendorId/ProductId/Revison numbers for your pen's hardware I can implement an autodetect of pen/tablet hardware.
