RadialMenu/Toolbar 0.4.6.326
Discussion in 'Software' started by incrediclint, Oct 15, 2014.
  1. Mesosphere
    5,315
    2,065
    Possible bug?
    I can work around this problem, but it seems like if I choose transparent background for the radial menu buttons (my preference) that only the non-transparent parts of the UI result in button selection on hover. If I select a solid color instead, the whole button activates on hover as desired.
    Edit: Not a bug. It is by design =)
    Work around here:
    http://radialmenu.36970.n7.nabble.com/Tips-tp8.html;cid=1431360496098-970
  2. Mesosphere
    5,315
    2,065
    Based on the last two posts, I'll probably immediately find the answer myself after asking, but can RadialMenu be brought up within the Modern UI? It doesn't seem to work for me.
  3. kellyuxd
    kellyuxd Pen Pal - Newbie
    21
    Can someone please let me know how to select a toolbar button (by touch) while the pen is near the screen? Also, I have a 1080p screen, is this preventing the toolbar from aligning flush to the right?
  4. ron2k_1
    992
    171
    What machine are you using? The developer coded it in such a way that touch+pen is device-agnostic and it universally applies across all devices of all sizes, resolution and even pen tech. You'll have to enabled it in the toolbar settings.
    Swiped from my Galaxy Note 4 using Tapatalk
  5. kellyuxd
    21
    Thanks, I'm using a Viao Flip 15A. Could you please point me out to where that setting is?
  6. ThureK
    ThureK Pen Pal - Newbie
    Hi,
    Can anyone confirm problems with the automatic profile switch for Zbrush64bit and clip Studio paint aka manga Studio? Cant get it to work. Zbrush32bit works fine though. Otherwise, great Software!
  7. BTS
    BTS Pen Pal - Newbie
    I don't have a keyboard and the surface pro 3 doesn't have a alt button
    Can anyone help me make a macro
    Its press alt
    Right-Click
    Release alt
    Its for a zoom command in zbrush
    This is all I need to complete my button menu
    Please help
  8. BTS
    WOOPS
    Minus and oemplus were zoom in and out
    Nm
    Love this thing so much
  9. prollygon
    prollygon Pen Pal - Newbie
    Windows now marks the install file for RadialMenu as malware... it won't download/run. Clint, please fix this!!
  10. Azzart
    2,246
    1,564
    so it's not my vivotab note that's gone crazy with the malware issue...
