RadialMenu/Toolbar 0.4.6.326
Discussion in 'Software' started by incrediclint, Oct 15, 2014.
  1. incrediclint
    219
    50
    Do NOT delete any stylus button profiles, it actually deletes TOOLBAR profiles. Update coming.
  2. Gary.M
    Gary.M Pen Pal - Newbie
    37
    On my SP3 stylus button remapping no longer works. The setting doesn't stick.
  3. incrediclint
    219
    50
    RadialMenu 0.3.8.274 - released December 14, 2014
    - Fixed: Double file open dialogs when adding a toolbar profile.
    - Fixed: Deleting stylus button profiles actually removed toolbar profiles.
  4. incrediclint
    219
    50
    Hmm, it's working on mine, all except for middle mouse it appears. Looking into it.
  5. Gary.M
    37
    Was trying to remap it to middle mouse button
  6. incrediclint
    219
    50
    RadialMenu 0.3.9.275 - released December 14, 2014
    - Fixed: Middle mouse button remapping not working for the stylus.
  7. Gary.M
    37
    That works great. Unfortunately I now have another problem: with radial menu running my on screen keyboard is acting up with the a key only: when I press it while typing this reply it selects all of the previously typed text and does not enter the letter a. This does not affect my type cover.
    EDIT: this only happens with metro apps, desktop seems fine. After more checking on desktop the letter w acts up here, sometimes it is a capital W, other times acts as ctrl+v (paste)
    Also disabling auto switch toolbar or radial menu does not work.
  8. incrediclint
    219
    50
    RadialMenu 0.3.10.276 - released December 14, 2014
    - Fixed: Issue with auto profile switch not working correctly.
    - Fixed: Profiles changing in radial menu in certain situations when 'Auto Profile Switch' is toggled off
  9. Gary.M
    37
    Thanks, that works fine now.
    I think I have discovered what is causing me problems with the on screen keyboard: I have TouchMe engine installed. If it is running when I run radialmenu I get the problems outlined above. I switch it off, restart RadialMenu and all is fine again.
  10. incrediclint
    219
    50
    It's probably an issue where they are interfering with each other's key injections. Both inject key commands, and if the original function of the key isn't blocked it goes through as well, or if a key isn't being released like one of the modifiers. Could also be something with the activation hotkeys for RM, I'm reworking some of the internals of RM and hopefully it'll fix these issues.
