R1F Upgrade
Discussion in 'Asus' started by DanielG, Feb 27, 2007.
  1. DanielG
    DanielG Pen Pal - Newbie
    I am new to the forums and to laptops but not to pc's or computers. I am just curious as to what can be upgraded on the R1F. I believe I can update the processor to a T7600 but I am not sure about the memory. (as far as if its soldered in, I haven't opened up my laptop yet) Also I was considering a hd upgrade to maybe a 7.2k 100gb? I was also wondering about the modular battery if anyone has any experience with it or if it is worth it. If anyone has any advice I would really appreciate. Thanks :)
  2. alphaswift
    923
    1. The CPU is (apparently) socketed. No one here on these boards has tried it yet.
    2. The memory upgrade is a no brainer and can go up to 4gb if you can afford the cost.
    3. Disk upgrade is straightforward. I have not done the upgrade on the R1 but with my previous laptops, this upgrade takes less than 15 minutes.
  3. kudoskun
    kudoskun Scribbler - Standard Member
    112
    From my experience, the 7.2K's are noisy. Going from a 5.4 to a 7.2 is a few milliseconds difference. Plus a 160 5.4K is similar to a 100 7.2K in price from what I have scoured the web. Im sure weekly deals exist that can make it easier on the wallet.
  4. Fido
    299
    7.2k will also use more battery.
  5. DanielG
    Aight thanks guys! I was also wondering about memory which is the best as far as manufacturers and performance is concerned, plus would increased memory increase battery usage?
  6. Kib
    Kib Pen Pal - Newbie
    I think it's only compatible with up to 2gb of ram, even if you put in 2, 2gb chips.
  7. P8RSON
    5,189
    No... the Intel chip can handle 4GB RAM.
  8. alphaswift
    923
    This RAM pricing is in $CAN, but check the difference between a 1Gb stick and a 2 gb stick:
    Notebook 667 MHz DDR2 200 pin SODIMM Non-ECC
    512 Mb DDR2 DDR2-5300SO/512 $ 53
    1024 Mb DDR2 DDR2-5300SO/1G $ 101
    2048 Mb DDR2 DDR2-5300SO/2G $ 696
  9. leewalk
    leewalk Microsoft Guy
    24
    To be clear, the R1F should accept 2x2GB (4GB) RAM (I'm going to try it soon) but the Intel 945GM chipset will limit the usable memory to a little over 3GB.
    The next version of Intels chipset will allow full use of 4GB (and more when using Vista x64).
    Lee
  10. chinesefireball121
    376
    So why does the ASUS website state that the R1F is only upgradable to 3GB of RAM?
Similar Threads - Upgrade
  1. COGBABY
    38
    5,465
