R10 Vs R15
Discussion in 'Toshiba' started by Brian, Jun 16, 2005.
  1. aim2
    aim2 Pen Pal - Newbie
    Hi, I just ordered the Toshiba R10 and customized it for more RAM. Is the R10 identical to the R15, just with customizable features? Or is there some sacrifice of performance, other than CPU speed, for the lower price?
    Thanks!
  2. Barry J. Doyle
    2,153
    The R10 is the exact same build and has the same overall features as the R15. Which processor did you opt for?
  3. aim2
    Thanks, that's good news. I'm not sure if the notebook came with Microsoft OneNote. Would you recommend buying that?
    For the processor, I just went for the standard Celeron 1.3 ghz. It should suffice for word processing and browsing and Minesweeper. If I feel like doing anything graphics intensive, I can use my desktop.
  4. Brian
    1,305
    You're right, you made a good economical choice. As for OneNote, you can get a free trial, so you might give that a whirl first to see if you'd even use it. I think it's a great app, but not everyone needs it.
