Q704 Fan Noise
Discussion in 'Fujitsu' started by HoyaNM47, Jan 1, 2014.
  1. stoneseeker
    3,684
    1,138
    wait, "desk dock"? Are there multiple docks for this thing? Or are we speaking of the same dock that he had it in for the tests?
  2. Mesosphere
    5,313
    2,060
    Yes, the keyboard is called a dock too, which maybe confusing.
  3. ThomasAn
    ThomasAn Pen Pal - Newbie
    29
    Ok, so to be on the same page ... this is the only "dock" that is meant to give full performance ? -->
  4. cothek
    cothek Pen Pal - Newbie
    If that's the case, we've got to be able to trick it into full speed mode.
    Edit: I've sent in a support request regarding this to Fujitsu...not holding my breath on a meaningful response tho.
  5. lwestfall
    lwestfall Pen Pal - Newbie
    Doh! So someone needs to test the Q704 in the CRADLE dock to know it's true potential! And then the question is, would anyone ever be able to get the Q704 to attain this maximum performance in the KEYBOARD dock and as a TABLET? I'm guessing Fujitsu will eventually give a BIOS update to get the Q704's tablet performance somewhat closer to the Surface Pro 2's performance, but there may be physical heat-dispersing reasons that only the CRADLE dock (with a bigger fan that pulls the air through the tablet faster?) allows the processor to go safely into full turbo mode....
  6. scrambler
    301
    19
    There are way too many suppositions at this time.
    Unless Fujitsu actually clarifies things, or someone actually gets the Desk Dock Cradle to test, we have no way of knowing.
    And unlike the Helix that has clear vents on the tablet and extra Fans in the keyboard dock to increase ventilation, the Q704 appears to have no such things.
    I guess we will have to wait for more units to be delivered and hopefully be picked by serious review sites.
  7. HoyaNM47
    HoyaNM47 Pen Pal - Newbie
    19
    Hi,
    I received my i5 Q704 this morning.
    Here is the first Geekbench test with the unit unplugged (from power) on "High Performance" in the Fujitsu settings and "Balanced" in the Windows settings:
    FUJITSU STYLISTIC Q704 - Geekbench Browser
    Here is the test with it plugged (to power) in and Windows on "High Performance" and the Fujitsu setting on "High Performance" as well:
    In both, it's attached to the keyboard dock with the built-in battery.
  8. HoyaNM47
    19
    Hi,
    I should have mentioned in the previous post that the temp runs about 66 degrees centigrade. Also, the fan is running all th tim like crazy.
  9. Mesosphere
    5,313
    2,060
    Hmmm... 2 for 2. Not encouraging ...
  10. cothek
    Looking like the "Performance Dock" may be needed...sadface.
