Professional illustrator in need of buying advice
Discussion in 'What Tablet PC Should I Buy?' started by lealla, Jun 8, 2017.
  1. lealla
    lealla Pen Pal - Newbie
    I'm a professional illustrator, and I need to buy a new laptop / 2-in-1 tablet combo / stylus. (Not Apple)
    I currently use my cintiq for all my work, but it would be great to be able to take some of my work away from the desk, especially for sessions with clients.
    Despite loving all my wacom products, I'm just not that keen on the Wacom Mobile studio. This is less of a cost problem, and more due to the fact that I would prefer something that is still somewhat like a laptop, with a keyboard. I also feel that the Wacom mobile studio seems a bit heavy and clunky by comparison...
    Anyway, here we go:
    1. What is your budget?
    up to $2500 AUD
    No
    Notebook convertible
    • 10 to 13-inches
    • Above 13-inches
    Australia
    No Asus or apple
    Ideally up to 5
    I will primarily be using it for drawing (Photoshop/painter), however I will also be doing a bit of page layout/google-sketch up and email/web.
    It must run windows.
    Primary: Photoshop / Painter, Secondary: Adobe Illustrator/Indesign, thirdly Microsoft office/Firefox ect.
    No
    No
    Screen Specifics
    Ideally 1080
    No
    Yes, as close to a wacom as possible.
    Component Specifics
    Ideally 500GB min
    A few USBs is important and HDMI is also good.
    Misc
    I'm quite keen on the idea of a lenovo, however I'm worried about the drawing experience and whether or not it is something that I'll be comfortable using, or if I'll end up just abandoning it in favour of my cintiq.
  2. thatcomicsguy
    3,085
    2,117
    You might want to do as I'm doing; keep an eye on the upcoming Samsung Notebook 9 series. -Both the 13 and 15.6" versions will use Wacom EMR.
    Discussion thread:
    http://forum.tabletpcreview.com/thr...d-15-flippers-with-windows-10-and-spen.72302/
    If the reviews are good when they start shipping, it might be the machine you're looking for.
  3. surfaceproartist
    2,983
    1,908
    I'm currently on the Yoga 720 15 bandwagon. It's an exceptional value.
    thatcomicsguy likes this.
  4. stoneseeker
    3,531
    977
    OP, since you specified a notebook convertible that "as close to Wacom Cintiq as possible" and listed devices at the 10" to 13" range as acceptable... Perhaps you don't prioritize the bigger 15" screens as heavily as the rest of us... in that case there are some other convertibles to consider alongside the 2 top picks mentioned above.
    Here is all the current Wacom EMR (very similar experience to Wacom Pro EMR) convertibles:
    Samsung Note book 9 @thatcomicsguy mentioned (upcoming)
    Fujitsu T936
    Fujitsu T726
    Toshiba Z20t-C (detachable)
    ...aaaaand thats it. Almost everything has gone Wacom AES now, which may not be a terrible thing, the jury is still undecided and it's obviously pretty subjective. Their are some others in slate form factor, but for convertible form factor that's it unless you start diving into previous generations.
    Of course, the king of painting still belongs to the fabled Fujitsu T90-- err I mean--, Wacom Mobile Studio Pro since it is literally the same Wacom Pro cintiq experience your used to in a portable slate, but it sounds like your looking for a convertible and I'm sure your already aware of Wacom's tablet offerings.
    Lapostata and thatcomicsguy like this.
  5. surfaceproartist
    2,983
    1,908
    There's also a Yoga 720 13.
  6. Marty
    2,671
    2,034
    I would get the upcoming:
    Samsung Notebook 9 Pro S
    • 15.6" 16:9 1080p Wacom EMR, i7-7500U, 16GB DDR4, Radeon RX 540, 256 GB SSD, 54Wh battery
    • 2 USB 3.0, 1 USB-C charging, HDMI, MicroSD, HP/Mic, DC-in
    • 13.67” x 9.41” x 0.67” @ 3.79lbs lbs (1.7 kg)
    Price TBA but almost certainly will fall under 2500 AUD.
  7. surfaceproartist
    2,983
    1,908
    Don't underestimate the impact on workflow and performance of a relatively rare HQ quad core processor.
  8. Marty
    2,671
    2,034
    I would agree, but from the the OP's specific comments wanting EMR and 1080p resolution:
    The specs of the Notebook 9 15" seem almost a perfect match! :thumbsup:
  9. surfaceproartist
    2,983
    1,908
    For what it's worth, the drawing experience on a MobileStudio Pro is vastly superior to the Galaxy Book. The S-Pen flavor of EMR and latest gen AES are really neck and neck now.
  10. Marty
    2,671
    2,034
    Interesting. What are the main differentiating factors that you notice?
Similar Threads - Professional illustrator need
  1. lealla
    566
