Problems with long HDMI cable
Discussion in 'EP121 Slate' started by anguscoleman, May 4, 2016.
  1. anguscoleman
    anguscoleman Pen Pal - Newbie
    52
    It is a problem I did not have in the beginning: the signal via hdmi to tv gets very unstable, then disappear completely when I use hdmi cables 5 mt long.
    No problem with a 1,5 mt cable.
    I changed several cables but it is the same: the signal has problems with longer cables. With other norebooks the cables work perfectly. It is just the ep121 that shows this issue.
    I would really to draw on ep121 and watch what I draw on tv, from a bigger distance.
    Any suggestions? Thank you very much.
    Angelo
  2. XJ12
    XJ12 Scribbler - Standard Member
    444
    112
    Miracast an option maybe? Use wireless instead of cable. Sounds like some kind of electromagnetic interference (EMI). Maybe a bad transformer or frayed charging cable if you are using power connection. Turn off Bluetooth or other emitting devices in vicinity. Like your cell phone possibly.
  3. anguscoleman
    52
    OK, I will try. Thank you very much.
Similar Threads - Problems long HDMI
  1. clayt0
    1,486
