Primarily for note taking
Discussion in 'What Tablet PC Should I Buy?' started by fog, Sep 13, 2016.
  1. fog
    fog Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    ~$400, but the lower the better. If I can save significant money for a minor compromise, I will.
    There is also some wiggle room upward.
    Yes, if it comes with a reasonable warranty.
    A keyboard would be nice to have, but not necessary.
    10 to 12 would be good. Will consider lower too, if there are significant cost savings.
    USA
    No
    Minimum 4 hours.
    Note taking, web surfing, media playback, sketching if possible.
    Windows 10
    10. What software and tasks do you intend to run?
    Would be good to be able to run a sketching program.
    No
    No
    Screen Specifics
    At 10 inch and above, would prefer to have ~FHD. Don't need much higher resolutions.
    Below 10 inch, can make do with ~HD, but would still prefer ~FHD.
    As for aspect ratio, 3:2 would be ideal. 16:10 should be fine too.
    Will be mostly used indoors.
    Yes. Wacom ES or N-trig would be nice.
    Component Specifics
    Storage: 64GB. Would prefer a microSD slot.
    RAM: 4GB. (Perhaps can make do with 2GB, but probably not enough for running a sketching program).
    USB 3.0 will be nice to have, but not necessary.
    As for the connector, would prefer USB Type-C, full USB-A, microUSB in that order.
    Misc
    Shouldn't be too heavy, as it will be carried in my backpack along with my laptop.
    Would like the pen to have a comfortable hover distance.
    Zerohour likes this.
  2. asdfrozen
    asdfrozen Pen Pal - Newbie
    I recently got an i7 Cube Book (Core m-6Y30, 4 GB memory, 64 GB storage, Windows 10, 1920x1080 10.6", Wacom EMR) for around $330. It also has a USB-C port (it does display out but probably no Thunderbolt, don't know about speeds or whether you can charge through it) and a micro USB 3.0 port (includes a dongle). It's a "sketchy" Chinese brand and the only place you can order it (as of now) is through GearBest, but so far it seems to be working very well. The micro SD card slot doesn't seem to be working though ... The battery life is also pretty good--around 8 hours for my use. You do have to buy the pen and keyboard separately though (I didn't--I have a couple Wacom EMR pens and a bluetooth keyboard lying around).
    You could also pick up a refurb Surface Pro 2. Woot's been selling them (http://computers.woot.com/offers/microsoft-surface-pro-2-10-6-tablets-13?ref=cp_cnt_wp_8_10) and you could probably find them for similar prices elsewhere.
  3. surfaceproartist
    2,930
    1,893
    Cube tablets are also available on Alibaba.
  4. fog
    Thanks for the replies.
    @surfaceproartist I'm reading your review of the Cube i7.
    How are the following options?
    Dell Venue 11 Pro 7140
    Dell Latitude 7350
    Dell Venue 8 Pro 5855
    Any idea what digitizers these use? I can get them for reasonable prices refurbished through Dell Outlet.
  5. surfaceproartist
    2,930
    1,893
    Unfortunately I haven't tested any of these.
