Power Management - Fujitsu T5010
Discussion in 'Software' started by Sasquatchbill, Dec 26, 2008.
  1. Sasquatchbill
    Sasquatchbill Pen Pal - Newbie
    Hey all -
    I'm having a hard time figuring out how to have different power management profiles depending on whether I'm plugged in or running on battery.
    I'd like to have high-performance settings when plugged in, and balance when running on the battery.
    How do I do this? There's gotta be a way, right?
  2. bait
    bait Pen Pal - Newbie
    88
    go to control panel, power options. select a profile, then click on change plan settings. then click on change advanced power settings. you'll see that you can change the "on battery" and "plugged in" settings independently, so just tailor it for your needs.
  3. Sasquatchbill
    But it then seems I'm tailoring that specific power plan for when I'm on battery and when I'm plugged in, which seems backwards to me.
    I'd rather be able to have it be "Balanced" when I'm on Battery and "High Performance" when I'm plugged in - that seems a lot more intuitive. That's how it worked on my old Toshiba M3500 (or was that a function of XP for laptops?)
    Is there a away to do that, or am I just out of luck?
  4. Grimnir
    758
Similar Threads - Power Management Fujitsu
  1. njweb
    769
