Post your c-140x drawings
Discussion in 'Acer (Gateway)' started by chriscannon, Aug 30, 2007.
  1. Meltdown
    Meltdown Me
    Does Art rage support layers and blending modes? I imagine it is pressure sensitive.
    The brush you used looks similar to the type you'd see in Painter which I used to like.
    BTW Painter would record time lapse painting data. In fact it also would store all strokes as vector data so you could paint at a low resolution for performance and then let the computer play back all your saved brush strokes on a higher res canvas while you go do something else. Pretty cool I thought.
  2. nikecar
    1,524
    Remember, Palm Trees live in warm climates, yours must be in a colder climate cuz I've got coconuts while yours doesn't.
    :p
    http://forum.tabletpcreview.com/showpost.php?p=66704&postcount=210
    Full version does support Layers, and yes, its pressure sensitive. Full version also includes more tools like paint tubes, metallic paints, and several other brushes.
  3. chriscannon
    905
    Im considering getting the full version, but i still have other things to buy first...
  4. schroder999
    schroder999 Pen Pal - Newbie
    61
    The full version of artrage has all the same layer blending modes as photoshop and painter such as multiply, screen, color dodge, etc, but I haven't tried them extensively to know if they work exactly the same or not for complex paintings.
    I would assume that they do.
    schroder
  5. tabletonthevista
    tabletonthevista Scribbler - Standard Member
    232
    That is impressive, chriscannon!
  6. chriscannon
    905
    Thanks!
    And just "chris" will do, tabletonthevista... :D
  7. Nominal
    Nominal Engineering Student
    199
    I did a mouse drawing of the cube man from my avatar (in my sig). I can't wait to try it again once I get my tablet.
    Hearing about how others are using their new c-140x's makes the wait more interesting. By the way, Chris, how are you liking doing your schoolwork on your tablet? Did you get the files copied over?
  8. chriscannon
    905
    Im homeschooled and such, so I might not need to much converting... but I think I start next week anyway, but i will let you know!
  9. tabletonthevista
    232
    Hmm, Chris, I'm just curious as to how old you are because the things you say suggest different things. Usually I think of you as college or beyond. But now that you talk about homeschooling....
  10. Nominal
    199
    At one point Chris said:
    That would make him about 17 years, 2 months old. :cool:
    Edit: I just watched the painting in your signiture, Chris. It's Great. :D It was just like watching someone paint on paper!
