Pointing devices on keyboards quit working
Discussion in 'Windows 10' started by WillAdams, Mar 18, 2017.
  1. WillAdams
    970
    414
    Would someone explain why there is no visible indicator for when one uses the special key / function key to disable a trackpad on Windows 10?
    I just bought a new keyboard 'cause I'd apparently inadvertently hit FN F5 turning my trackpad on my Toshiba Bluetooth Keyboard off --- apparently managed to do the same thing to the new one.
    All it would take is a little icon in the notification area....
    Anyway, does anyone know the magical key combination on an IBM USB Travel Keyboard with Ultranav to enable/disable the Trackpoint? Doesn't seem to be F8 or FN F8 as expected.
  2. WillAdams
    970
    414
    Turns out the problem is actually that Windows d/ls and installs a driver which disables the Trackpoint/trackpad. Solution is to d/l and install the right one:
    j5gc16ww.exe
    dellaster likes this.
