People really need to stay away from the tx1000 (tx1000 vs T2010)
Discussion in 'Hewlett Packard' started by 3quent, Oct 23, 2008.
  1. ogym76
    ogym76 Pen Pal - Newbie
    thanks for help.. here are some answers and other question :)
    What OS do you have running on your machine?'
    windows vista premium 32bit.
    if I simply turn it on and touch the screen it does not react. Is there a button I have to press before it or adjust something in the windows?
    try using your fingernails instead of the finger surface..
    I tried it many times but also nothing as if it were dead :eek:
    I bought this tablet on ebay as a refurbished item. It is quite new!
    thanks
    gyorgy
  2. kanehi
    kanehi Scribbler - Standard Member
    197
    Not all tx1000 are touch screens, it's an option. The screen is pressure sensitive and doesn't use a digitalizer pen like some high end tablets. I have the tx1100 and it works great. You also have to practice on how to write on the screen so the tablet can learn. I set mine to a larger nib tip so the tablet can recognize lines better. Buying from eBay is 50/50 chance of getting what you expected. Refurbished is usually warranted for 90 days if bought from a store. If you bought from eBay then cross your fingers and hopefully the seller will take it back. Sometimes eBay is "as is".
  3. topboxman
    topboxman Pen Pal - Newbie
    Take a look at the device manager and see if touchscreen is there. I believe it's under HID. If you can't find it then you don't have a touchscreen.
  4. 3quent
    3quent Pen Pal - Newbie
    Please tell me how to update BIOS (or where to find it) for my tx1250eo tablet.
