Pen Stuck on Left Click
Discussion in 'HP TouchSmart TM2 (Wacom)' started by ChronoT52, Jul 21, 2010.
  1. ChronoT52
    ChronoT52 Pen Pal - Newbie
    27
    Hey guys, long time since I've posted here.
    My pen encountered some water three days ago, and since then it seems to always be holding the "left mouse button" down. When I hover over the desktop, it drags a blue highlighted selection box around.
    Any ideas on how to fix it? Any help is appreciated.
    Thanks in advance!
  2. Nichod
    Nichod Scribbler - Standard Member
    147
    Perhaps get a can of compressed air and try blowing it into the cracks around the button. It's possible something got jammed in there that is causing it to be stuck.
    You can alternatively purchase a replacement. Or as a temporary solution disable the right click and just use the touch and hold option in Windows for right clicking.
  3. ChronoT52
    27
    Forgive me, I think I was a little vague. The physical button works fine. The problem is that when I hover over the screen with the stylus, no buttons pressed, it is perceiving a held left mouse click event.
  4. Nichod
    147
    Nope. I understood it. It's still possible something got stuck from the water getting in there. Dust mixed with water can be a little sticky.
  5. ChronoT52
    27
    Oh, excellent! I'll try to find a can of compressed air and try this.
  6. ChronoT52
    27
    Well, it seems the stylus has fixed itself.
    Nichod - I greatly appreciated your assistance.
  7. Nichod
    147
    Might have just needed to dry a little.
Similar Threads - Stuck Left Click
  1. kneehowguys
    964
