Pen latency test
Discussion in 'Hardware' started by surfaceproartist, Nov 4, 2016.
  1. Marty
    2,455
    1,783
    In my experience doing the fast circles test is that EMR has significantly lower latency than N-Trig.
    However, I haven't tried this in Sketchable. Perhaps if you tested in CSP you would start seeing measurable differences.
    siddhartth likes this.
  2. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    918
    488
    But it does affect the distance between the pen tip and the digital ink - [latency]*[speed]=[distance] - so taking the picture right when the ink is rendering where your hand moved slowest (at the bend) will mask the difference between the results.
  3. surfaceproartist
    2,951
    1,853
    Here is another look at the iPad Pro and Procreate using only straight strokes. You'll see the distance from the tip to the ink remains pretty consistent.
    ATIVQ likes this.
  4. surfaceproartist
    2,951
    1,853
    Here's the Surface Book with Clip Studio Paint.
    ATIVQ and Marty like this.
  5. Marty
    2,455
    1,783
    Could you try the same test on EMR?
  6. surfaceproartist
    2,951
    1,853
    Wacom Cintiq Companion 2, same settings as the Surface Book. Without lookin at this frame by frame, results look identical to me.
  7. Marty
    2,455
    1,783
    I think the EMR test looks slightly faster to render the first stroke update (past the initial 'tick').
  8. Azzart
    1,798
    1,197
    Surface book feels slow compared to the other two.
  9. surfaceproartist
    2,951
    1,853
    Probably is a bit slower, since it's just Clipboard. I'll measure frames and do the m3 Surface Pro 4 later today.
    kvoram likes this.
  10. surfaceproartist
    2,951
    1,853
    But remember every frame represents only ~4 ms.
Similar Threads - latency test
  1. Steve S
    298
