Pen digitizer problem. a strip can't write anything.
Discussion in 'EP121 Slate' started by monmo, Apr 25, 2011.
  1. monmo
    monmo Pen Pal - Newbie
    Hi all,
    I just received EP121 today, but I found my wacom function doesn't work.
    There is a 3 cm width strip under the webcam that can't use wacom pen.
    This is my situation.
    2011-04-26_0405 - CodyTW's library
    Do you know how to fix it ? it's a defect, right?
    Thank you.
  2. JustDavid
    JustDavid ASUS EP121 Slate user
    178
  3. CF77
    2,303
    If you use Artrage..do U have the same problem?
  4. thierryb
    1,383
    299
    I have seen your video. I had the same issue with my TM 2 one year ago. I solved it by a reset of the calibration of the pen, then a calibration.
  5. monmo
  6. monmo
    I tried to reproduce the problem in Artage.
    2011-04-26_0746 - CodyTW's library
    Red vertical red is the strip that is not working.
    I write some green lines, it's still not working in the strip, but have a connected straight line if I just leave the not accessible zone.
    Hope to find a solution @@ Thank you.
  7. monmo
    I tried it many times, but it's still not working.
    I can use my finger to draw at the pen-broken strip, but Wacom pen can't.
    Is it a Calibration problem ? or hardware detect ? thank you.
  8. CF77
    2,303
    Return it..sounds like a hardware issue.
  9. monmo
    Got it, I just submitted the replacement form from Amazon.com. Hope I can get the working one as soon as possible. @@ Thank you.
  10. oztabletpc
    oztabletpc Tablet PC Since 2003
    37
    It's a faulty digitizer connection. seen it many times over the years although it is very uncommon. Send it in for repair / replacement.
