Pen Calibration Trick
Discussion in 'EP121 Slate' started by smslocum, Aug 4, 2011.
  1. Bubble7
    Bubble7 Pen Pal - Newbie
    54
    Hi, Steve S
    I see it now...will try again!
    Thanks!
  2. Bubble7
    54
    I read somewhere need to convert the X and Y while calibrate in landscape mode!
    Am I doing it wrong? please help...
  3. Bubble7
    54
    Here is a look of the command window...
    BTW...how to make a screen capture with this T902?
  4. fadesurf225
    fadesurf225 Pen Pal - Newbie
    Okay, I will try to be as clear as possible while trying to decipher some ambiguity. The following 2 codes have been corrected. The first is for portrait mode (height is greater than the width). The second is for landscape mode (width greater than height). To be honest, I'm not sure if portrait calibration will work because I've never tried it. I don't know what will happen if the input coordinates do not much the screen specification range.
    Portrait - Anyways, without changing your X-and-Y coordinates from your picture on Post #83 and your code from Post #78, you should be using the following:
    Code:
    tabcal lincal novalidate XGridPts=10,75,150,225,300,375,450,525,600,675,750,825,890 YgridPts=10,60,160,320,480,640,800,960,1120,1280,1440,1540,1590
    Landscape - However, since you have indicated in post #82, you are using “landscape mode”, your X-and-Y coordinates should be flipped to the original coordinates that you have stated in post #74. The code in landscape should be the following:
    Code:
    tabcal lincal novalidate XGridPts=10,60,160,320,480,640,800,960,1120,1280,1440,1540,1590 YgridPts=10,75,150,225,300,375,450,525,600,675,750,825,890
    Only ONE of these codes should work. Make sure there are no spaces between the numbers, and no spaces on either sides of the "= signs".
    As for taking a screen capture, I believe it should be the following key combination: 'fn + prt sc'. Then you'll have to paste the capture onto an image-editing program like Microsoft Paint or Photoshop, etc.
  5. Steve S
    8,395
    3,888
    <<...As for taking a screen capture...>>
    Although Print Screen performs the desired function, I typically recommend Snip (look in your Program Menu (Win7) or the All Apps view(Win8)). Snip is more flexible than Print Screen.
  6. Bubble7
    54
    i use the code copy from your post, still error, i really dont know why?
  7. Bubble7
    54
    found the snip tool, thanks, Mac is much easier..
  8. fadesurf225
    Can you verify that you have the tabcal.exe file on your device? Just search for 'tabcal' in the start button.
    EDIT: I mean, tabcal should have already came with your tabletpc. But perhaps the file was deleted by accident somehow...
  9. Bubble7
    54
    I don't have the T902 with me now, what if I can't find the "tabcal.exe"?
    Can I re-install again?
  10. Bubble7
    54
    tabcal is there, it call up 16 point calibrate window...
    im so frustrated with this t902...
Similar Threads - Calibration Trick
  1. jnjroach
    1,566
