Pen Calibration Trick
Discussion in 'EP121 Slate' started by smslocum, Aug 4, 2011.
  1. manuelcalavera
    manuelcalavera Scribbler - Standard Member
    402
    21
    Ok I found the problem. I had forgot that the resolution in EP121 is not like ThinkPad Tablet 2, so I changed the data and now it works ( with some help in Lenovo's forum ).
    But the problem that me and other users are experiencing is that this method works on our tablet like a free-run software. It even asks to save it or not but in the end nothing happens and nothing changes.
  2. tgwallbank
    tgwallbank Pen Pal - Newbie
    39
    I ran the trick but fudged a few calibration points so I tried to reset the pen calibration in windows control panel but for some reason when I do this the screen info tells me the calibration has been removed but the reset button is not greyed out and the trick will not run again, telling me to reset, which I have done. Anyone else had this? I must be missing something simple!
  3. johnh
    johnh Pen Pal - Newbie
    33
  4. Bubble7
    Bubble7 Pen Pal - Newbie
    54
    When I input
    tabcal devicekind=pen lincal novalidate XgridPts=10,60,160,320,480,640,800,960,1120,1280,440,1540,1590 YgridPts=10,75,150,225,300,375,450,525,600,675,750 ,825,890
    Then press Enter...I got an error
    'tabcal' is not reconized as an internal or external command,
    please help!
  5. Steve S
    8,396
    3,890
    <<...When I input...>>
    Bubble: In the first line, there is a space in the number 440: "4 40" And that number is clearly out of sequence. Possibly that is your problem?
  6. fadesurf225
    fadesurf225 Pen Pal - Newbie
    There's also a space between the 750 and the comma on the YgridPts axis.
  7. Bubble7
    54
    Wow...
    Thanks guys, I'll try again!
    :thumbsup:
  8. Bubble7
    54
    hi,
    the error still there, i cant figure out why?
    tabcal devicekind=pen lincal novalidate XgridPts=10,75,150,225,300,375,450,525,600,675,750
    ,825,890 YgridPts=10,60,160,320,480,640,800,960,1120,1280,1440,1540,1590
    this is what i input...any idea?
  9. Steve S
    8,396
    3,890
    <<...this is what i input...any idea?..>>
    ...You still have a mis-placed space in the Ygrid array: YgridPts=10,60,160,320,480,640,800,960,1120,1280,1 440,1540,1590
  10. fadesurf225
    Bubble 7 - It also seems that the X and Y plots may have been inverted. Are you calibrating in portrait mode?
Similar Threads - Calibration Trick
  1. jnjroach
    1,566
