Pen Calibration Trick
Discussion in 'EP121 Slate' started by smslocum, Aug 4, 2011.
  1. Bubble7
    Bubble7 Pen Pal - Newbie
    54
    now I have almost perfect calibration, should I reinstalled Wacom driver?
    To draw I mainly use Artrage, like it simple ui!
    :thumbsup:
  2. kurt_hectic
    kurt_hectic Scribbler - Standard Member
    374
    Hey,
    Is it possible to export\import this calibration? maybe some entries from registry editor?
  3. lblb
    1,198
    242
    Hi kurt_hectic,
    I don'thave my tablet around to verify but I believe that in Win 7 (I don't know about Win 8) the calibration data for the normal 4-point calibration is stored here in the Windows registry:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TabletPC\UserLinearityData
    If yours is also stored there, you should be able to just copy the string of numbers for that entry if you want to export your calibration data.
  4. johnh
    johnh Pen Pal - Newbie
    33
    Mine just says (value not set) here. There IS data in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TabletPC\LinearityData,
    which changes after running tabcal. I'm not sure why you'd want to export this because it's presumably machine-specific and can drift over time. I find need to refresh the calibration from time to time.
  5. porongo
    porongo Pen Pal - Newbie
    43
    Is there anyone using Win 8.1 who tried to run Calibration trick with success? I mean, I´ve got pen calibrated after running the coordinates, but touch goes bananas after that...
  6. Bubble7
    54
    Did you install Wacom drivers after that tricks?
    I found that tricks works well, but not after re-installed the Wacom driver!!
  7. Chris_Brandt
    Chris_Brandt Pen Pal - Newbie
    Thank you from 2016 for this post! I wish I'd looked this info up years ago. So much wasted effort with poor calibration...but things are looking up for the future. Thanks!!!!!
Similar Threads - Calibration Trick
  1. jnjroach
    1,566
