Pdf viewer in qt?
Discussion in 'Asus (Android)' started by etienne, Mar 25, 2012.
  1. PF4Tablet
    PF4Tablet Pen Pal - Newbie
    94
    You are killing us!
    Thaks, I will keep testing and reporting bugs if I find any, at least that I can do to help :)
  2. PF4Tablet
    94
    1.9 Works better indeed but just in portrait mode
    If I switch to landscape mode the scribbling is terribly off setted to the right (around 1 cm)
    I believe that you will get a better speed if you make the line thinner.
  3. PF4Tablet
    94
    The PDF annotation merger works
    I will keep testing for finding any wrinkles .
    Thanks again
    PF
    PS: BTW how do I delete layers in a PDF if I need to? Let's say one of the scribbles overlaps the text and I want to remove it...
    I know I can hide layers but ..let's say I want to delete a specific scribble.
  4. TheTwo
    TheTwo Scribbler - Standard Member
    102
    Hi PF,
    thanks for testing.
    Deleting layers in PDFs isn't supported by any pdf tool I know. It is possible to use the TouchUp tool of Acrobat X to delete the Object (picture in the layer). This removes the picture (annotations), but not the layer in the layer navigation bar.
    TheTwo
  5. meditans
    meditans Pen Pal - Newbie
    Hi, quick question for d.goryachev: do you plan to reduce the height of the brush tool in future releases?
  6. d.goryachev
    d.goryachev Scribbler - Standard Member
    275
    Why? :)
    v 0.2.0 with minor bugfixes, mainly concerned with freehand tools positioning errors.
  7. PF4Tablet
    94
    It would be nice if you could use a sort of .cfg file so some of us could adjust the size of the line for drawing.
    I assume that this is the easiest way to give this option (easier than adding buttons to the menu bar I guess)
  8. PF4Tablet
    94
    Just tested the 0.2.0 ..it is better in portrait mode
    Still has problems in landscape mode (lag and displaying the writing with some delay)
  9. meditans
    Because in the very majority of my pdfs, the height of the brush tool is roughly twice than the height of the text, and this leads to unpleasant effects when three consecutive lines are sublined (see the picture).
    Maybe a .cfg file, as PF4Tablet suggest, would be a perfect solution..
  10. resuS
    resuS Pen Pal - Newbie
    94
    Hi D. Goryachev. There is a problem with thickness of brush indeed. May I suggest the solution: it would be nice if brush would be the same thickness at the screen in every scale. For example 5 mm is the real size of brush and keep it with whole range of scales.
    P.S. Is it possible to open dictionary app instantly without seeing "a"-shor_translation and clicking "Next"?
