Pdf viewer in qt?
Discussion in 'Asus (Android)' started by etienne, Mar 25, 2012.
  1. resuS
    resuS Pen Pal - Newbie
    94
    Hm... Have you thought about creating new note app based on that you have done now?
  2. PF4Tablet
    PF4Tablet Pen Pal - Newbie
    94
    Any way to merge the freehand drawing with the PDF file so we can export these to the PC?
  3. d.goryachev
    d.goryachev Scribbler - Standard Member
    275
    Updated, new freehand mode. Unfortunately i've no time now, so progress is slowed :) Sources updated too, at same location.
  4. PF4Tablet
    94
    Seems faster but for some reasons the scribbles are sliding down around 2 mm after your stop writing.
    Also it seems that the new algorithm is drawing in some kind of rectangle which is refreshed on the spot.
    The edges of that rectangle are visible while you are scribbling.
    Nice use of the "Clear the area" function! with that you can clear the scribbles for an entire page with one move!
    Well done, I would say that by the time when you reach version 2 this pdf reader will be by far better than the stock one.
  5. meditans
    meditans Pen Pal - Newbie
    Also, when you draw straight orizontal lines with the brush tool, after you finish the stroke it "inflates" and the actual stroke becomes wider (in height), englobing part of the superior and inferior lines in most of the pdf I own. I'd really prefer a shorter (in height) highlighter (or a setting to decide the width).
    I know I could use the rectangle to highlight a sentence, but the combination of lag (there is more lag in rectangle tool that in brush one), and the need to choose "filled rectangle" from the popup menu for every choice, makes this solution a bad one. What do you think about removing the popup menu and add to the tools three different entries for "rectangle", "filled rectangle" and "clearing rectangle"?
  6. chris-lawrence
    chris-lawrence Pen Pal - Newbie
    37
    Brilliant! -- My xournal pdfs now look excellect on the eee-pc
  7. TheTwo
    TheTwo Scribbler - Standard Member
    102
    Hi,
    I've added support for merging annotations from MuViewer to the PDF in the FPDFAM tool. The PDF must be located in the books folder at the SD card or in the eeeNote.
    Please report back problems.
    TheTwo
  8. PF4Tablet
    94
    Thanks a lot The Two
    I will definitely test this
  9. PF4Tablet
    94
    Bugs
    Bug with erasing scribblings using the rectangle.
    I went back an forth between landscape mode and portrait for a couple of times. I created scribbles and I wanted to delete them
    by selecting them with a rectangle. I selected a big area, I was zoomed to a half of the page (around 210%) and I selected "clear area" .
    The scribbles dissapeared. I jumped to the next page and I came back, the scribbles were still there
    Bug with entering a page number an pressing "Enter" dos not take you to the page number in question. The virtual keyboard still remains active, nothing else happens
  10. d.goryachev
    275
    Thank you! :)
    P.S.
    I've released v 0.1.9 as hotfix - some major performance issues was resolved.
