Palm rejection for Toshiba Encore 2
Discussion in 'Toshiba' started by Gourav Saha, Mar 30, 2017.
  1. Gourav Saha
    Gourav Saha Pen Pal - Newbie
    Hi all,
    I got myself a refurbished Toshiba Encore 2 for just $100. I did not buy the "write" model because it was 3 times costlier. My first and foremost purpose for buying this tablet is note taking. I have a question is this regard. For easy notetaking purpose, palm rejection is very important. Is palm rejection a software issue of a hardware issue? If it is a software issue, which software should I download? It is a hardware issue, which stylus should I buy?
    Cheers!!
    Gourav
  2. WillAdams
    962
    409
    Hardware, which is fixed when one uses the stylus in the Write model.
  3. Gourav Saha
    Hi Will,
    Thanks for your reply. Does Toshiba Encore 2 (not the write model) supports active stylus like Wacom's and Ntrig?
    Cheers!!
    Gourav
  4. WillAdams
    962
    409
    No.
  5. Steve B
    Steve B Moderator Moderator
    3,334
    503
    That's correct, as far as I know. My hunch is that is why the "Write" model is more expensive. The Write model supports an N-trig style pen, I believe.
  6. WillAdams
    962
    409
    Wacom AES.
