P1610 display / resolution problem
Discussion in 'Fujitsu' started by riven, Sep 13, 2007.
  1. riven
    riven Pen Pal - Newbie
    21
    hi all, would like to seek for advice
    i am quite happy with my P1610, except the extra small fonts
    and too detailed screen resolution that make my eyes very tired,
    tried to change the resolution / fonts but it just cannot fit the screen size,
    now still using 1280 x 768
    dunno why it cannot be changed to 1024 x 768,
    screen will become 4 x 3 ratio, and when in portrait mode, cannot show full display of some programs
    pls help...........
  2. Mistah_C
    Mistah_C The Reviewer
    100
    so you're saying that although you change the resolution, the only thing that changes is how much of the screen is displayed/ but u still have the same font size and icon size, etc.?
  3. magnu55
    magnu55 Pen Pal - Newbie
    74
    riven, instead of changing the screen resolution, one option to try would be to try changing the DPI. In XP, this can be found under Display Properties > Settings > Advanced > General > DPI Setting
  4. riven
    21
    thx for advice, ^^
    magnu55, i have tried changing the DPI already, but fonts on some program, e.g. MSN, still very tiny..... and i have changed most of the display setting but editing menu bar fonts, icon fonts, etc etc
    Mistah_C, no , I mean i can change fonts size by changing the resolution,
    but then there will not be full screen display, the left and right hand will be truncated under some resolution setting
  5. kureshii
    1,478
    You'll need to adjust your Intel GMA Driver settings (in Control Panel). Go to Display Settings -> Aspect Ratio, make sure it's set to full screen. Not sure how that goes for Vista, I'm talking about XP.
  6. riven
    21
    i am using XP as well, u mean i can lower the resolution and expand the display, right ?
    thx kureshii, will try ^^
  7. kureshii
    1,478
    Yup... I had to contend with playing MechCommander on a shrunk screen (old game, only supported up to 800X600 =P) until I realised, LOL
  8. tasomaniac
    tasomaniac Pen Pal - Newbie
    25
    I dont know. But I have a question to you. In youtube there are videos about calibration problem with P1610. Do you have the same problem?
  9. riven
    21
    cannot find that function !!??
  10. kureshii
    1,478
    I've included a screenshot to make it clearer, sorry about the previous confusing post.
