P1510 or X41T, Help me.
Discussion in 'What Tablet PC Should I Buy?' started by andersonche, Aug 23, 2006.
  1. andersonche
    andersonche Pen Pal - Newbie
    After seeing UMPC, I would like to have one. But finally, I decide to buy a small tabletpc.
    Now both P1510 and X41T seem good. Anybody could tell me pros/cons about these two laptops?
    The following things are important to me:
    1. Quality of display (brightness, view angle etc).
    2. Battery life.
    3. Heat
    4. Keyboard.
    Any comments would be greatly appreciated :)
    Thanks.
  2. P8RSON
    5,189
    As to the P1510:-
    1. The build quality is simply superb.
    2. Battery life is excellent.
    3. Heat.... what heat!
    4. Keyboard is very professional and has the right tactile feel.
    It's ultra lite and portable.
    However, bear in mind, depending on how you percieve the screen but don't forget it operates opposite to any other....i.e. you don't need a pen to draw on it.
    Do I like it.... Most certainly... Just as long as it befits the task you need it for.
  3. Steveoph
    Steveoph Pen Pal - Newbie
    27
    I'm sure you can find a review for the x41t through this site. But I've been reading up on Tablet PCs for a while and everything I hear about that is just great, and if you don't mind the waiting game I hear there should be the x60t coming out mid october-ish.
