Ordering the M7
Discussion in 'Toshiba' started by ryanmartini, Dec 15, 2006.
  1. QuantumXL
    QuantumXL Pen Pal - Newbie
    22
    No arguments, Right choice if you like the size than your set. Good luck man, and i myself like the M7.
  2. jreagles16
    jreagles16 Newbie in Training
    Whats the battery life like?
  3. SimsHsia
    3,293
    Hi jreagles16,
    The M7 is meant to be a desktop replacement unit, however, you'll get around two and half to maybe just over three hours of battery life. :)
    If you tinker around with the Toshiba Power Saver Properties, and put it in the "Long Life" mode, you may get up to 5 hours, but everyone's mileage may vary on that one.
  4. diekenny
    diekenny Pen Pal - Newbie
    33
    Under XP, with most of the power saving options enabled (brightness at 25%, screen turns off after 2mins, etc) I'm able to get about 3 hours during classes (ie. Lots of journal, a little web browsing, no real heavy lifting) with the newest battery (4700mAh). Though I also have a few 4400mAh left from my M200 days which only get about 2 hours, though this is more likely due to their age as they drop from 30% to 2% life directly.
    Under Vista with similar power settings I get around 2h20m, though this could likely be improved some.
  5. The Niles
    380
    From other accounts Vista improves battery life not decreases it. I have heard several people commenting who have tried Vista that it has increased battery life for them. I would classify this as a freak occurence.
  6. WEBSRFRINMD
    WEBSRFRINMD M200, M7
    Not according to other posts on this board. I am barely getting 1.5 - 2 hours of battery life. There's nothing freak about this. It's a brand new M7 with a brand new Vista RTM installation.
    I'm reporting from actual experience with my M7 and Vista.
  7. ryanmartini
    ryanmartini Pen Pal - Newbie
    23
    well if i am taking notes, i dont need max screen brightness, wifi on, and bluetooth. What are some good quotes with power savings on, cpu down, screen, etc...
    thanks!
    -ryan
