OneNote needs...
Discussion in 'OneNote, Evernote and Organizers' started by dceggert, Apr 6, 2016.
  1. dceggert
    3,122
    565
    I thought OneNote 2013 was pretty much perfect until....duh duh duh duhhhhhhh
    You hand your machine to someone to read what you have in your status report (trying to save paper) like in Star Trek and 'oops, what happened...?' They pushed the "X" when they took your slate and deleted your page.
    Is there a way to lock the page? If not, there needs to be!
  2. JoeS
    6,361
    5,161
    Ouch! I can't find a way to make notes 'read only', only ways to password protect sheets.
    You may still be able to find your notes though, for example in auto-generated recycle bin folders. I store my notebooks on OneDrive and there are folders like these:
    OneDrive\OneNote\ProjectX\OneNote_RecycleBin
    The pages stored there can be moved to your preferred location and opened again in OneNote iirc.
  3. lblb
    1,207
    254
    Are you talking about the close button at the top right? If yes, I don't know if there is a native OneNote way of doing it. You could try using NoClose (Ctrl + 1 enables/disables the close button):
    http://www.donationcoder.com/Software/Skrommel/#NoClose
    If that doesn't work, or if you want to modify it a bit, we can try a few things with AutoHotkey.
  4. dceggert
    3,122
    565
    Actually, selecting, scrolling, and making changes needs to be locked out. I think this is a usage case that has not been even looked at. Up until now sharing of information has been over a projection screen or sending a file to someone else. Handing a computer to someone like a piece of paper is so natural of a way of sharing that it is amazing it has gone unaddressed.
    What I am going to do before I try that again is figure out an easy way to disable the touch screen completely. Not everyone knows how to handle a TabletPC when handed one. Any information on the screen is subject to going haywire in this scenario. The unexpected results can be disastrous!
  5. lblb
    1,207
    254
    dceggert likes this.
  6. dceggert
    3,122
    565
    Nailed it. It works in Win 10 as well! This is exactly what is needed. The pen still works but touch is off. Now I can hand it over to someone and then toggle it back on when I get it back! Perfect....thanks a bunch!
