onemix 3 yoga
Discussion in 'Other Brands' started by laigood, Mar 20, 2019.
  1. norazi
    norazi Pen Pal - Newbie
    27
    I have read really bad reports of Chuwi's build quality and I would rather pay more for better build quality since these China-books have almost non existent post sales support.
  2. jnjroach
    4,050
    1,442
    Any Surface n-trig pen will work, as will some from HP and ASUS. Also the WACOM MPP that supports both AES and N-trig should work.
  3. WhenUtry
    WhenUtry Pen Pal - Newbie
    27
    Thanks for this. I've seen good reviews/writeups on Chuwi products but have not really made the jump because they rarely speak of quality and durability. Not sure also about sponsored posts.
  4. paperwastage
    paperwastage Pen Pal - Newbie
    Someone has a full teardown of the one mix 3s
    No m.2 slot. There's a dormant sim slot
    17:15 in this teardown for one mix 3s to see it. 23:15 for mention about lack of m.2, 24:35 for soldered 512GB chip
    BillyZ and Marty like this.
  5. paperwastage
    I did get a one mix 3
    Initial impressions
    1) wished they gave a 16GB + m.2 option. I can live with
    2) bigger device. Harder to handheld thumb type, but easier to type like a regular keyboard
    3) keys are white with white backlit. Gen 1 was black with white backlit, makes it easier to type even when backlight is off
    4) preactivated windows, but secure boot was off
    Chromiumos/chromeos came up, battery/sound/wifi works Touchscreen/pen didn't, need to look into it further
  6. laigood
    laigood Pen Pal - Newbie
    19
    intel 10th cpu version is coming
  7. FerradalFCG
    FerradalFCG Pen Pal - Newbie
    I've just received my onemix 3 pro with i5 10th gen.... and I'm wondering... will it be charged with a 18w power delivery power bank??
  8. Steve S
    8,244
    3,756
    <<...will it be charged with a 18w power delivery power bank??.>>
    Check the output rating of the AC adapter; this is typically the wattage that would need to be provided...
  9. FerradalFCG
    Thanks, the charger is 30W, but do you think that with 18w powerbank it will be able to charge the netbook being powered off??, maybe this AC adapter is ok for charging while working with 30w... and I supose that 18w will be unable to charge while turned on.... but will it be while powered off???
  10. Steve S
    8,244
    3,756
    While powered off, it will probably work. Just be aware that some devices are set up so that they will only charge from their own AC adapters...
    FerradalFCG likes this.
