onemix 2 yoga
Discussion in 'Other Brands' started by laigood, Sep 19, 2018.
  1. norazi
    norazi Pen Pal - Newbie
    27
    The SSD is soldered onto the motherboard... its that black square chip above the CPU/SOC in the 2nd photo. The brand is "Longsys Foresee"
    jvloyola likes this.
  2. jvloyola
    jvloyola Scribbler - Standard Member
    191
    116
    That’s sad news, thank you for checking
  3. franzander
    franzander Pen Pal - Newbie
    51
    On the discord channel someone seems to have observed that some chargers only work after you power cycle the device, so maybe try rebooting while the charger is connected?
  4. franzander
    51
    Thanks, so you were able to get the heat sink off without trouble? Just wondering because on discord someone said theirs was glued on somehow.
  5. jnjroach
    3,938
    1,263
    I received mine this week but I didn't receive the Stylus I ordered, I'm waiting to hear from Geekbuyig on the situation. So far its a good little machine, the fan get loud and it's a bit warm.
  6. BillyZ
    BillyZ Pen Pal - Newbie
    if you haven't thrown out the packing material, double check it again. my stylus wasn't inside the box. it was in its own little white tubular cardboard box separate from the One Mix 2 box. When I opened my package, I wasn't even looking for the stylus and it kinda just fell out on its own when I was on my way to the garbage.
    You can see how it's packed separate in this video, it's to the right of the One Mix 2 box.
  7. norazi
    27
    I just tried that with all my chargers and it doesn't work
    Yep, just 4 screws on the heatsink and it comes right off very easily.
    My stylus came in a separate (much smaller) box from the netbook. Maybe double check the package? If you press Fn+ESC while plugged in to power, you can adjust the fan speeds. Lower fan speeds will throttle the CPU faster though.
  8. jnjroach
    3,938
    1,263
    Thanks.....the nice box came in another box made of the same type the stylus was shown but it wasn't in included as a separate item as well.
  9. Ishman
    Ishman Pen Pal - Newbie
    25
    Some additional videos have been uploaded:
    Comparison of the original OneMix Yoga and 2S
    A basic review of the Yoga 2S
    Fan noise
  10. yodamiked
    yodamiked Scribbler - Standard Member
    141
    88
    Looks like the screen unfortunately utilizes pwm (at least it appears to from those videos).
