Note Taking Tablet for University
Discussion in 'What Tablet PC Should I Buy?' started by sashpta, Oct 24, 2017.
  1. sashpta
    sashpta Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    <350 Euro
    no
    media/mobile tablet, NOT a 2-in-1 thing
    10 inches
    Germany
    no
    atleast 8 hours
    Note taking, PDF reading, little browsing
    I don't care about the OS
    One Note and pdf reading / editing (adding notes to the pdf)
    No
    No
    Screen Specifics
    atleast 1080
    Yes, I need to be able to see it through glare from the sun
    I want to use a pen with it
    Component Specifics
    atleast 16GB, preferable expandable, but no must have
    Just USB, rest is no must have
    Misc
    What is about the Amazon Fire HD 10 (2017) or Samsung Galaxy Tab A 10.1?
  2. violajack
    violajack Scribbler - Standard Member
    398
    436
    The Fire HD does not have a digitizer, so any aftermarket pen will be frustrating at best. The Galaxy Tab A 10.1 is a solid bet if you get the one with S-Pen. It must be the one that comes with the S-Pen so the digitizer is built in. Handwriting on that will should be as nice as pen on paper, a great experience for taking handwritten notes.
    sashpta likes this.
  3. sashpta
    Isn't a digitizer the thing where you write on a piece of paper and what you wrote then appears on the tablet?
    Cuz I'd like to write directly onto the tablets screen
    According to Amazon the Samsung tab a in Germany isn't a pen supported however they say there should be a version of the tab a that supports a pen...
  4. Shiratori
    Shiratori Pen Pal - Newbie
    50
    25
    Here is the one with the S-Pen on the German Amazon site. It comes in within your budget as well.
    WillAdams likes this.
  5. WillAdams
    992
    439
    In a tablet context there are a couple of different digitizers:
    - capacitive ones which are touch --- these are typical
    - active ones which require an electronic pen --- some of these are a superset of capacitive (Wacom AES, NTrig) while others need a separate digitizer (Wacom EMR)
  6. SciuriusRex
    SciuriusRex Pen Pal - Newbie
    25
    the "digitizer" is the sensor grid & hardware control system that keeps track of the stylus location/screen contact.
    Yes, the Intuos is a standalone digitizer, just like the pad on a Yoga Book.
    Capacitative (non-pen) touch-screens have digitizers built into the screen assembly: i.e. any smartphone.
    A stylus-enabled tablet pc (pen that writes on the display screen) will have the digitizer built into the screen as well. On the surface above the LCD (synaptics; Wacom AES), or on a frame behind the screen (EMR).
    In all of these cases, the digitizer is mapping & measuring the input device (finger and/or pen).
