Nooby question about the stylus tips
Discussion in 'Asus' started by P8RSON, Nov 10, 2006.
  1. alphaswift
    923
    The R1F came with extra nibs for the pen....so the tips actually wear out? Considering that they are only used on the surface of the tablet, I would not expect much wear.
    So for the people that have had a few tablets, how long does a tip last on average? Can you tell if it's wearing by feel alone?
  2. Barry J. Doyle
    2,153
    The plastic tips (nibs) do in fact wear, but for the most part it is the finest point/tip that becomes less accurate on the screen. I personally am not that picky about how sharp my pen tips are, but I am sure there are users who prefer a "sharper" point for writing.
  3. saranya
    saranya Pen Pal - Newbie
    50
    also a newbie, how of you change the tip?
  4. SimsHsia
    3,293
    You have this metal "ring", there is an insertion or break point; it's like tweezers. You just align the ring to surround the worn-out nib, then pull the nib out. To put in a new one, simply insert the new nib into the pen, and you're good to go. :)
  5. P8RSON
    5,189
    There should be a tool to remove the tip that comes with the tablet pc.
    Edit: Apologies SimsHsia. You posted as I was compiling my answer.:)
