No pen in slate mode
Discussion in 'Microsoft Windows 7' started by craigt, Apr 10, 2009.
  1. craigt
    craigt Pen Pal - Newbie
    92
    Lately, (can't recall what I installed that could have caused it), the pen is unusable in slate mode. It works fine in laptop mode until it clicks into place as a slate. The pen cursor just disappears. Has anyone else had this problem?
  2. DRTigerlilly
    7,578
    742
    301
    what PC do you have? and maybe you should try a system restore (go back to an earlier time), to see if you can locate the culprit.
  3. craigt
    92
    Sorry, I'm so used to being in the Lenovo thread that I didn't think to post my system.
    I have a Lenovo X61 tablet. I haven't yet tried doing a restore. I uninstalled a couple programs and it came back for a few minutes, then I lost it again. No pen once again.
  4. DRTigerlilly
    7,578
    742
    301
    had you tried installing the wacom drivers for the pen, or you just left it as detected by the system?
  5. craigt
    92
    I installed a few drivers from Lenovo, but let Windows choose the rest. Since it seemed to work fine 'out of the box' I left it alone. You don't happen to know offhand where to find the appropriate Wacom driver, do you? I'll see if I can find it.
    I found and downloaded the Wacom tablet PC driver. Is there any reason not to try it out?
  6. craigt
    92
    Well, I installed the Wacom driver, but to no avail. What's odd is that, now, I get pen recognition sometimes while in slate mode, but not always. Sometimes it just ignores the pen as soon as it snaps in.
    I'd like to re-install the correct drivers in the right order. Does any other Lenovo x61 user happen to remember in what order they installed which drivers? We should also be sure to get a thread up once the RC is out to everyone.
  7. DRTigerlilly
    7,578
    742
    301
    i don't think the driver order really matters, the only reason it would make a difference was if there was some kind of conflict.
    That said i'm on the Windows drivers vs the drivers from Wacoms site and don't have this problem, i'm inclined to think its likely something you installed afterward, or did you tweak any of the services or startup programs?
  8. craigt
    92
    I didn't mess with any startup programs or services. I did allow Windows to install everything it found on its own, then added a few Thinkpad drivers, and finally the Wacom driver you mentioned.
    Maybe I'll try to uninstall the Thinkpad and Lenovo drivers and let Windows try to fill in the blanks.
    I forgot to mention that when the pen quits working I can pop the screen up an inch or so and it works again. Usually, once it's down again it stop working once more.
  9. craigt
    92
    Once I removed the Wacom drivers and let Windows do its thing, everything in Device Manager that was once "Wacom ..." is now "Virtual ...", i.e.
    Virtual Keyboard Driver
    Virtual Keyboard Interface
    Virtual Media Keys
    with the first two entries showing up twice. I also don't have a TIP. It's as if Windows is treating the pen as a mouse only.
  10. DRTigerlilly
    7,578
    742
    301
    and at the point that you've raised the screen, it hasn't switched the rotation or anything? I'd be much more inclined to do a fresh install, and try to troubleshoot the issue that way, but i can entirely understand that may not be practical.
