Newbie on Tablets: Need help for buying options.
Discussion in 'What Tablet PC Should I Buy?' started by shane155, Aug 8, 2017.
  1. shane155
    shane155 Pen Pal - Newbie
    1. What is your budget?
    500 or less.
    yes. Why not?
    No preferences.
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    Not sure -- it would be for school, youtube, movies, and some math programming.
    I live in California, USA.
    Nope.
    Not many? Plus where I am there is always a charger. College, home, library, etc.
    Primarily emailing, web surfing, word processing, notetaking, some programming, and watching youtube videos.
    No preference.
    Microsoft office in general, maybe visual studios sometimes for programming. That is about it.
    Not really.
    Doesn't matter
    Screen Specifics
    No preference.
    not really.
    I would like a pen.
    Component Specifics
    No preference
    Microusb and sd are okay.
    Misc
    nope.
    nope.
  2. Kumabjorn
    3,781
    1,808
    You have a flexible approach so there are lots of alternatives, going for most bang for the buck I'd say that a last generation Surface Pro 4 would be attainable on some sale, and it will likely come bundle with pen and Type Cover in a scenario like that
