New ArtDock for Surface Pro
Discussion in 'Microsoft' started by DoctorBunsenHoneydew, Feb 17, 2013.
  1. genics
    genics Pen Pal - Newbie
    hey DoctorBunsenHoneydew can you make a artdock for thinkpad yoga s1? thanks you so much.
    czm2000 and thewish like this.
  2. andr3ytp
    andr3ytp Pen Pal - Newbie
    Hi,
    I got Surface Pro and tried all version of artdock and still give me this erorr:
    View image: PROBLEM
    Let me know if any of you had this problem and how you fix it.
  3. czm2000
    1,015
    192
    I second that. Would be very grateful.
    Sent from my GS4
  4. rirawin
    rirawin Scribbler - Standard Member
    214
    18
  5. surfaceproartist
    2,934
    1,914
    Yes, I disabled that portion of the original ArtDock. If you go into the individual scripts, you should find where I've commented out the lines pertaining to disabling touch. (It was a while back and I don't remember where or what the lines are specifically). I believe all the necessary files are in the archive.
  6. rirawin
    214
    18
    do you mind linking me to the installation file again please, I'm on my mobile so I need to download the files again and have a look. Plus can you point me where specifically what I should be looking for and need to change please?.
  7. surfaceproartist
    2,934
    1,914
    I'll have to go back in to the files and check them out. I'll post here when I've had a chance to do that.
  8. rirawin
    214
    18
    Thank you very much, I had a look but I'm not sure what to do exactly?.
  9. surfaceproartist
    2,934
    1,914
    The version of Autohotkey you're running is probably incompatible with our Artdock script. Download and install http://ahkscript.org/download/1.1/AutoHotkey111403_Install.exe. When the installation is done, make sure to run the script before attempting to run ArtDock.
  10. surfaceproartist
    2,934
    1,914
