New ArtDock for Surface Pro
Discussion in 'Microsoft' started by DoctorBunsenHoneydew, Feb 17, 2013.
  1. DoctorBunsenHoneydew
    DoctorBunsenHoneydew Scribbler - Standard Member
    168
    23
    LATEST VERSION 2 (9/3/13)
    - fixed dpi scaling bug.
    - reduced the UI by a ton.
    - Added swanky new Tguard toggle!
    - Made batch file and shortcut that handles ArtDock and Tguard with a single button.
    - Moved default ArtDock location to top, in order to avoid interference with touch keyboards.
    Here's a version of ArtDock I made specifically for the surface pro. I personally don't lieka billion buttons, and want it to be minimal, usable, and look like it belongs in the W8 UI.
    Credit goes to Konartist3D for the awesome original script. He made all of the icons and original scripts for the series 7 slate and ep121. All I did was hack it a little to make it work for w8 and my personal workflow. ;)
    And even more credit goes to this guy, who developed the underlying code to make this possible. RawInputControlTest.ahk
    Install Instructions:
    1) Install the newest version of AutoHotKeyhere
    2) Unzip the file here to the root of your c drive. So it should look like "C:/artdock"
    3) Drag the "ArtDock" shortcut onto your windows toolbar.
    NOTE: THIS VERSION HAS A BUILT-IN TOUCH DISABLE THAT YOU CAN TOGGLE. YOUR TOUCHSCREEN IS NOT BROKEN, I PROMISE.
    - click the artdock shortcut the first time, and all touch will be disabled.
    - click the artdock shortcut again (with pen, touchpad or mouse), and touch will toggle back on.
    This is a feature that I personally cannot work without, as the default windows palm rejection isn't super reliable.
    Hope you all find this useful!
    jaekqubp likes this.
  2. zbrush
    zbrush Pen Pal - Newbie
    43
    Thanks for sharing the script.
    I am running the original script an it seems to have some touch problems. When I rest the palm on the screen and paint then the buttons are not working. If I don't touch the screen with the palm then everything works fine.. any idea why ?
  3. DoctorBunsenHoneydew
    168
    23
    I noticed that problem as well. It happens on the series 7 slate too in windows 7, so it's not unique to the surface pro or windows 8. Only happens with big wide inputs like your palm. Doesn't happen with finger inputs.
    Wish i knew why that happens. Might I suggest some fashionable fingerless gloves perhaps? :D
  4. zbrush
    43
    I'll give it a try :D
  5. bathala
    bathala Pen Pal - Newbie
    wait, surface pro has palm rejection . i can draw with my palm on the screen but now with this program i have to wear a glove.
    Ha no thanks
  6. DoctorBunsenHoneydew
    168
    23
    You should actually use the program, re-read what we are talking about, and then edit your comment. No rush, we'll wait for you.
    To zbrush: I suggest trying one of those SmudgeGuard gloves. Apart from being generally nice for drawing, mine does a pretty good job of preventing that palm-touch error we're talking about. Not a real solution of course, but it works for me.
  7. lblb
    1,207
    254
    Hey DoctorBunsenHoneydew,
    Thank you for your work on this terrific script. While I don't have a Surface Pro (I don't need the extra power and prefer the larger 16:10 display of the comparatively-dinosaur-ish EP121), it's really good to see that this truly game-changer of a script can be adapted to a state-of-the-art system. There may be a future after all for this script (this one created by Konartist3D but also the simpler one on which it's based) beyond the EP121 and S7!
    I'm sure that soon enough SP users will realize just how absolutely awesome this script is (and the others like it) and how powerful it is for art programs. If it works as well on the SP as it does on the EP121 and the S7, this thread will probably become quite popular! I mean: being able to use with your fingers any number of customizable shortcut buttons while Touch is actually turned off, that's about as good as it can get short of having physical buttons to press.
    Keep up the good work!
  8. darthjosh
    darthjosh Pen Pal - Newbie
    Hey I downloaded this and its really great except one problem, I am left handed. I tried looking into the file to see if I could change it myself but I am not a programmer by any means. How can I move this to the right side of the screen?
  9. DoctorBunsenHoneydew
    168
    23
    I suppose I could make a lefty version as well. If I have time this weekend I'll whip one up.
    Also noticed that the slider undo/redo buttons sometimes do phantom clicks. I replaced it with separate undo/redo buttons that work more predictably.
    Hopefully I can get both revisions in by this weekend.
  10. zbrush
    43
    You can move it anywhere on the screen you want. Just drag the area with 3 horizontal bars. ( i am using the original script but i guess it has the same structure)
    Edit : looking at the pictures on the top i see that it's different and is missing the area with 3 strips.
