Negotiation Troubles
Discussion in 'Acer (Gateway)' started by jeevesme, May 27, 2008.
  1. ThatDude
    ThatDude Pen Pal - Newbie
    Hi-
    I'm look to purchase the C-142XL for college. I'm trying to get a sales rep to lower the price, but I've had no luck. Here is my most recent conversation with a sales rep:
    Any ideas or tips?
  2. leaftye
    4,127
    Make sure the rep(s) have you contact information. It's very likely that they'll contact you in the near future with a better deal. Patience favors the buyer, impatience favors the seller.
  3. Spartikiss
    Spartikiss Scribbler - Standard Member
    215
    Its also usually better to try to get a deal by phone... Just a thought.
    -Spart
  4. nikecar
    1,524
    you aren't going to get the XL for the HP price. not going to happen. If $600 is the way you want to spend, drop GW and take the HP.
  5. ClockworkDoc
    ClockworkDoc Pen Pal - Newbie
    37
    I doubt that they will go below $1000 for an 141 XL
  6. tcp_dpm
    tcp_dpm Pen Pal - Newbie
    I think you meant the 142 XL because last weekend they had the 141 for 699 and the 142 for 1099.
    Actually, just checked and the 142 XL is still 1099
  7. Grimnir
    758
    ThatDude,
    hi, I'll refer you to the sales rep that I used.
    Firstly, your epectations are set too high. I do not think Gateway will priceMATCH the HPTx2000...it is way too low. You can use it however as a bargaining tool to get the price to be lowered, perhaps a free bag, and perhaps free shipping. There is probably no way you are going to pay the same price as the HP. Secondly, I havent seen the price for the 142XL that low before on the Gateway site. They may have already put as much of a discount on it that they can handle. The rest of the discounting is the Sales rep cutting into their own income. Be considerate of them. If you can only afford the HP now I would start saving now so you can afford the more expensive and better performing TPC.
    I think the price is pretty damn good already, the gateway definitely is the most bang for the buck...I paid 1300 or so for mine, already you are paying less :)
    MY sales rep: Emma Rogers, 1-800-846-2042 ext. 32324 Phone
    Emma.Rogers@Gateway.com
    Tell her Grimnir sent you
  8. tcp_dpm
    Seriously, I don't know who would buy a 141 right now with the 142 being only $100 more.
  9. Rex Orbis2
    Rex Orbis2 I Bleed Black and Gold
    44
    I thought the only difference between the two was SP1. That's definitely not worth $100.
  10. ScubaX
    1,011
    The 141 that is available is the X model, which has the Intel GMA X3100 Graphics vs th ATI Mobility™ Radeon X2300 HD 256MB. Plus the 142XL has a faster CPU with more cache, 1GB more memory, larger HD, faster BUS speed. Definitely worth $100 more.
