Need Pen Enabled Content Creator Laptop
Discussion in 'What Tablet PC Should I Buy?' started by hitman, Oct 9, 2021.
  1. hitman
    hitman Scribbler - Standard Member
    172
    General Questions.
    1. What is your budget? $2000 - $4000
    2. Would you consider purchasing used/refurbished? No
    3. Do you prefer a media/mobile tablet like the iPad, Windows tablet PC, or notebook convertible? Convertible Laptop
    • Above 13-inches 15-16 inch screen
    5. Which country do you intent to purchase from [where do you live]? China/Online
    6. Do you have any preferences to brand loyalty or dislikes? No
    7. How many hours battery life do you require? 4-6 hours
    8. What will be the primary usage scenario of this tablet? (Email/Web Surfing/Drawing/Word Processing/Entertainment/Notetaking etc) Email, Office, Web Surfing, Note taking, Diagram Drawing, PDF annotating, Photo & Video Editing, Document Design, Music recording/Production, Online Zoom/Skype calls
    9. Do you have an OS preference? For example, do you own an iPhone and a Mac, or are you a Windows fan? Do you own an Android device and use Google services frequently? Windows/Android
    10. What software and tasks do you intend to run? (Microsoft Office or other Word Processing Suite/Photoshop/3D Studio Max/Autocad etc) MS Office, Adobe Creative Cloud incl. Photoshop, Premiere Pro and InDesign, Ableton Live DAW
    11. Do you intend on playing Games? If so please list. No
    12. Would you like to stream content through your home theater system? No, through monitors
    Screen Specifics
    1. Any preference on screen resolution? OLED
    See the above linked FAQ for guidance No
    See the above linked FAQ for guidance Wacom preferred but not essential
    Component Specifics
    1. What size Hard Drive and Memory do you require? Would you like expandable memory? 1TB/2TB SSD, 32-64 GB Ram
    2. What sort of inputs do you require, if any? Would you like full-sized USB and SD card slots? Are microUSB and microSD ok? Do you require HDMI inputs? HDMI slot Preferred, SD card slot
    Misc
    1. Other non specific items ~ please add other items you require not covered above? High quality audio
    2. Additional requests ~ anything other you wish to take into consideration? Webcam
    END COPY
  2. thatcomicsguy
    3,406
    2,490
    There are several Samsung 2-in-1 machines which are very nice for drawing and well within your price range, but they don't meet your minimum RAM specs. The best of them max out at 16 GB. They also all run exclusively on 1080p screens, which might be limiting.
    That leaves two options, but you'll pay for them!
    The HP ZBook X2 can host up to 32GB ram, (upgradeable) and I believe it uses Wacom tech for the pen. It has a 14" screen, (which I consider a bit on the tight side). It's hard to find them new now, but I did see a couple on Amazon.
    Then there's the Acer Concept D 9. Wow! Now that is a machine to stand in awe of. These are the specs:
    • Intel® Core™ i9-9980HK processor Octa-core 2.40 GHz
    • NVIDIA® GeForce RTX™ 2080 with 8 GB dedicated memory
    • 17.3" 4K UHD (3840 x 2160) 16:9 IPS
    • 32 GB, DDR4 SDRAM
    • 1 TB SSD
    The manual says there's a 32GB RAM limit, but otherwise, it's a powerhouse. It should have no trouble running your DAW and video applications. And I love the giant 4K screen! It uses Wacom's excellent pen system, though it won't be as feature-rich as their Cintiq line. Wacom always downgrades in some way when it licenses its digitizer tech to third party OEMs; you'll probably not get tilt, for instance, but you'll get button capabilities and pressure sensitivity. It ought to run art programs nicely. I don't know what the sound card or speakers are like.
    The biggest downside is that it's a $5000 machine.
    FWIW, I do video work on my Samsung Notebook 9 Pro well enough, (16 GB RAM), though it does overheat on big renders unless I throttle it down in Davinci Resolve, but running at 50% render speed works no problem. So it takes about 1 hour of render time per hour of 1080p video. The speakers are junk, but the sound card is fine with headphones. Plus you can always use a USB sound card when in doubt. The Samsung line would be a budget option for sure, but if you want to draw, it's an excellent system. Nobody does Pen and Touch like Samsung.
    Cheers!
  3. doobiedoobiedum
    1,292
    580
    Much as I love my zbook - there are definite limitations and I really don't like the keyboard for typing. I'd also prefer the bigger screen of the Concept D9 but you should also consider the Concept D7 - very similar but fits within the budget.
    thatcomicsguy likes this.
  4. hitman
    172
    Thanks to thatcomicsguy and doobiedoobiedum for your advice and recommendations. The conceptD9 does indeed look amazing but might just be too big as it would take up much of my carry on baggage when travelling. Going to look more closely at the conceptD7 and also the Samsung range. The 360 Pro looks nice but am put off by talk of a particularly dull screen. Have also been looking seriously at the Asus Zenbook Pro OLED and wonder what people thought of this as an option?
    Sent from my SM-A520F using Tapatalk
  5. thatcomicsguy
    3,406
    2,490
    The Zenbook looks like a powerful laptop, but I couldn't see any option for a proper stylus other than third party pens which tend to be so-so at best. Plus I didn't see any indication that the screen can fold flat or into a tablet configuration. Maybe I was missing something in the specs or model options?
    The Samsung screens aren't OLED, but I find the one on my 2017 model to be quite adequate if not perfect. There is some light bleed if you are on an all black screen, but nothing which distracts, (unless a user is OCD and just can't stand knowing it's there). The biggest downside I'd say is that the resolution is 1920 x 1080. I sometimes think it would be nice to have a 4K screen, but again, when I'm busy at work on it, I don't notice it. If it was 4k, then I'd probably have to work with the GUI elements magnified just to read the already small Windows fonts.
  6. hitman
    172
    Thatcomicsguy, interesting that you wouldn't expect the Zen Duo to have an adequate pen for my needs. The Samsung range does look very nice and the pen technology is definitely an attraction. Which model do you think would be best suited to the usage I've described?
  7. hitman
    172
    Also should add that in my area can only find the Acer ConceptD 3 Ezel available and wondered if anyone had experience of using this?
    Edit: Have just found a Concept D 7 Ezel for sale although the price is very high. Wonder how
    much of an improvement this will be over the Samsung Pro 360?
  8. Shogmaster
    4,416
    1,627
    3 Ezel uses AES pen instead of EMR so avoid. 7 Ezels' edge over Samsung 360 is the CPU/ GPU combo mainly.
    360 you are dealing with ULV Quad cores and 7 Ezel you are dealing with H series hexa/octo cores. Way more muscle in multi core tasks. Also you get RTX mobile GPU options with 7 Ezel. 360 you are stuck with Intel onboard GPU.
  9. doobiedoobiedum
    1,292
    580
    You're behind the times old man. Acer updated the new Ezel 3 to a 14" and 15" and you can choose between AES and EMR
    https://www.acer.com/ac/en/US/content/conceptd-series/conceptd3ezel
    Price for the EMR model is not bad compared to the 7 and the 9 - except it's an HD screen.
    Just be careful - there is an EMR version but you have to check it's available in your country.
  10. Shogmaster
    4,416
    1,627
    Why you whipper snappers! *shakes fist at cloud*
    doobiedoobiedum likes this.
Similar Threads - Need Enabled Content
  1. daddyfish
    19
    1,969
  2. nerys
    1,546
