Need New tablet please help
Discussion in 'What Tablet PC Should I Buy?' started by Austin jasss, Jul 11, 2018.
Tags:
  1. Austin jasss
    Austin jasss Pen Pal - Newbie
    1. What is your budget?
    $150 USD
    New Only
    Media/mobile tablet
    8 to 11 inches
    USA
    No
    3000mah +
    Reading, Movies, Web Surfing,
    Android
    Chrome, Netflix, Webnovel
    no
    Possible
    Screen Specifics
    1920x1200
    Indoor
    No
    Component Specifics
    8GB with expendable memory
    MicroSD, MicroUSB
    Misc
    preferable an Android vanilla skin as possible
    Built-in Bluetooth
    Built-in WIFI
    Can buy a case and screen protector for it.
  2. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    677
    221
    @Austin jasss if you can stretch your budget somewhat, Xiaomi Mi Pad 4 is decent in all regards. Otherwise, check out Teclast, Chuwi and other Chinese brands reviewed on techtablets, and watch out for sales.
