Need help on deciding what hybrid/2-in-1 to get for last year of high school and college
Discussion in 'What Tablet PC Should I Buy?' started by ducksonquack, Jun 25, 2014.
  1. ducksonquack
    ducksonquack Pen Pal - Newbie
    Hey!
    These past few days I have been looking into laptops. I came across the convertible laptop/tablets and was intrigued. Being a student, the size and ability to take notes with a stylus seem insanely useful. I'm just not sure as to which convertible to get. I'd really appreciate your input!
    1. What is your budget?
    Around 1.5k
    I would prefer not to.
    Convertible
    5 to7-inches
    7.1 to 10-inches
    10 to 13-inches
    Above 13-inches
    Around 13-inches
    USA
    Nope!
    Around 8 would be nice
    Email, web surfing, note-taking, extensive typing, microsoft office use, Netflix, Hulu, Youtube
    I prefer Windows
    As far as I know, only Microsoft Office and Adobe
    It would be a nice ability to have, but I'm not expecting this out of a convertible.
    Not really
    Screen Specifics
    1080p would be nice
    Yes and yes
    Yes, but I don't know anything about pressure sensitivity nor have I ever tried any brands.
    Component Specifics
    I'm not sure. I know I'll have multiple applications up at once. I'll be saving a lot of music, documents, PDFs, PowerPoints, books, and things of the sort. Expandable memory isn't required.
    USB is the only required, but I would like SD and HDMI.
    Misc
    I enjoy black-lit keyboard, but not required!
    Nope!
  2. jnjroach
    4,003
    1,383
    For what you're looking for, in the size you want:
    New:
    Surface Pro 3
    Lenovo ThinkPad Yoga
    HP Pro x2 612
    Fujitsu Lifebook T904 (will be over your budget)
    Fujitsu Q704
    Used or Refurb:
    Fujitsu Lifebook T902
    Lenovo ThinkPad X230T
    Fujitsu Q702
    Most of these are 11.6 to 13" screens (The Fujitsu T series are the only real 13", Lenovo ThinkPad Yoga is 12.5)
    Personally I'm a fan of the SP3, it is the perfect size and ratio for reading and note taking but gaming performance is lacking.
  3. ducksonquack
    Hey,
    Thanks for the input!
    I've been considering both the SP3 and Yoga. My worry with the SP3 is that I like to use my laptop on my lap a lot, and the keyboard that you can buy with it just does not seem fitting for this. Also, the kickstand might get irritating. I'm also worried about it being too much of a tablet. I don't know too much about the Yoga, but I've heard so many good things. How good is it for note-taking? And this may seem kind of silly, because it is, but the ThinkPad stickers and red dot in the middle of the keyboard irritate me for some reason. The design just isn't one of my favorites.
    I don't really know anything about HP or Fujitsu, but I've heard a lot of good things about Fujitsu. Can you explain to me why it's so popular?
    Also, what about the Sony Vaio Duo 13? I know Sony is getting rid of Vaios, but I like them. I don't know how good their convertible is though.
    Thanks!
  4. jnjroach
    4,003
    1,383
    Vaio Devices are orphan machines everywhere but Japan now, I personally wouldn't purchase them....
    I'm using the SP3 on my lap to type this right now, works fine.
    Fujitsu is a Business OEM and create machines for the Enterprise, they tend to be expensive but well built, same with the HP Business Lines. Since your primary purpose is School and Notes nothing beats the SP3 currently...
  5. ducksonquack
    Would the Thinkpad be better for me than the SP3 since my primary want is a laptop rather than a tablet? I essentialy just want a laptop that's very portable with the ability to take notes on. Also, does the SP3 have a lot of glare? It'd be nice to be able to use it outside, but that won't work if the glare is bad.
  6. ericshmerick
    ericshmerick Scribbler - Standard Member
    108
    SP3. Seriously.
  7. jnjroach
    4,003
    1,383
    I'm a big fan of the Surface Pro 3, with Type Cover the SP3 is right at 2lbs where the ThinkPad is 3.5+lbs and the 16:9 of the ThinkPad isn't as conducive for reading and note taking... but if you want a laptop the ThinkPad is a good option.
  8. Snaap
    Snaap Pen Pal - Newbie
    I was deciding between the yoga 2 pro and the Thinkpad yoga a while back. I bought the yoga 2 pro and I'm very happy with it.
    For your needs the Thinkpad Yoga is probably better (pen) so I'd definetly check it out if I were you.
