Need help choosing pen for Elitebook x360 830 g7
Discussion in 'Hardware' started by Corvus, Apr 6, 2021.
  1. Corvus
    Corvus Pen Pal - Newbie
    I am looking for a suitable active pen for my new Elitebook x360 830 G7. The problem is I am not sure which one would be compatible. The HP spec states that one can get "optional" HP Active Pen G3 for it (it is however mentioned only in the promo material, not in the user guide, and there is no information about the digitizer technology used). The webpage for HP Active Pen G3 has however no information about compatibility with this model, and the last version of HP Pen Compatibility chart is too old for this generation of Elitebook. The digitizer is not N-Trig (or rather it does not work with my Surface pen), so I guess it is probably AES (2.0?) - but I do not have suitable pen to verify it. (nb. if it turns out that it really is AES 2.0 other cheaper pens should also work)?
    Anyway - any help would be appreciated :)
