Need He with 3G on HP Slate 2
Discussion in 'HP Slate' started by leadlong1422, Mar 29, 2014.
  1. leadlong1422
    leadlong1422 Pen Pal - Newbie
    Hello Bronsky
    can you help me? How to do use SIM 3G on my HP Slate 2. I'm from Vietnam and my tablet is running Window Pro 8.1. I installed Slate 2 driver by link : Release Notes
    Help me pls. Thanks you
  2. Declive
    Declive Pen Pal - Newbie
    Hi leadlong
    This is for windows 7 but I think it works well in windows 8.
    Remember to install the drivers for your Broadcom Mobile tablet.
    All the HP Slate 2 it comes factory unlocked. I had the same problem and solved it this way:
    Open Network and Sharing Center-->Change adapter settings-->Right click on "Mobile Broadcom Connection (HP un2430 Mobile....)--> and click in "Diagnose"
    A message with a yellow triangle appears, then next and close.Let him finish process.
    If you have a sim card installed appear the name of your ISP in the list of connections. Use HP Connection Manager to manage connections.
    Remember, when you install a sim card you must completely shut down the Slate 2.
    Hope I've helped.
  3. leadlong1422
    thanks Declive
    my problem is ok. i had search driver for HP un2430 mobile and installed. all is ok.
